Progress
A project log for MultiBot CNC v2
A low cost 3D printed CNC that can be built with minimal tools yet is capable of great things.
david-tuckerDavid Tucker 03/26/2021 at 01:380 Comments
I have my laser wired up and running now with full control over power in GRBL.  So far I have been able to slice up a few sheets of paper and burn some wood.  I have not tried cutting wood yet.
I went ahead and used the NEJE PWM/Temp module to act as an intermediary between the laser and GRBL.  It is not needed but it has a few nice features. First it can read out the temp of the laser module and display it at the push of a button, even while the laser is running.  It can also be used to manually drive the laser for focusing.  It also displays the requested laser power when under GRBL control, that acts as a nice double check so I can see if GRBL is doing the right thing.  Finally it has an on/off button so you are less likely to accidentally trigger the laser when your not ready for it.
I printed out a nice housing for the module so it is not quite so sketchy.
I'm just getting started but here are some observations so far
