Good Vibrations
A project log for MultiBot CNC v2
A low cost 3D printed CNC that can be built with minimal tools yet is capable of great things.
david-tuckerDavid Tucker 05/07/2022 at 00:161 Comment
At work I needed to precisely measure the vibration frequencies of a device.  I pulled out a M5StickC that I had laying about and wrote some custom code for it.  This is a small ESP32 based micro controller with a built in LED display, battery, accelerometer, compass and enough processing power to run a proper FFT in a reasonable amount of time, all in a package the size of your thumb.
Anyway I needed to measure as high a frequency as I could, but out of the box the accelerometer was only outputting data at around 100 Hz, much too slow for my needs.  A little dig through the documentation and I came up with this function to bump the update rate to 1 KHz.
void MPU6886_I2C_Write_NBytes(uint8_t start_Addr, uint8_t number_Bytes, uint8_t *write_Buffer)
  Wire1.beginTransmission(MPU6886_ADDRESS);
  Wire1.write(start_Addr);
  Wire1.write(*write_Buffer);
  Wire1.endTransmission();
void speedUpSampleRate()
  uint8_t regdata;
  // try and boost the i2c update rate, to 400KHz
  Wire1.setClock(400000);
  // up the sample rate
  //regdata = 0x08; // 4 KHz, no filtering
  regdata = 0x00; // 1 KHz, 230 Hz lp filter
  MPU6886_I2C_Write_NBytes(MPU6886_ACCEL_CONFIG2, 1, regdata);
  // turn off sample rate divider
  regdata = 0x00; // no divider
  //regdata = 0x01; // 1 divider
  MPU6886_I2C_Write_NBytes(MPU6886_SMPLRT_DIV, 1, regdata);
void setup()
  M5.begin();
  M5.MPU6886.Init();
  speedUpSampleRate();
 I also needed to take the collected data and convert it to the frequency domain via a FFT.  I wanted to do this on the device itself, rather than sending it over the serial port before processing.  I quickly found the Arduino FFT library, it seems to be what everyone uses.  It worked fine out of the box, it was fast and seemed accurate.  However it had one problem, the amplitudes that came out of the library were suspect at best.  I dug around for a while and found that others had come to the same conclusion.  After experimenting with all there ideas I came up with this simplified version of the Arduino FFT library that fixes things so the amplitudes are valid. I spent the better part of a day pushing data through this to verify it is in fact working now.
Note that when you call ComplexToMagnitude the input is the sine()/cosine() pair for each frequency and the output should be the amplitude and phase shift for each frequency.  However this code only computes the amplitude and basically trashes the phase shift info.  It is a shortcoming that needs to be fixed someday.  This is 90% based on the developer branch of the arduinoFFT library, but backported to the main branch without reorganizing the code.  Just  save it to a arduinoFFT.h file and drop it into the same folder as your .ino file if you want to use it, no need to import it as a library.  I stripped out all the legacy calls, and replaced them with a single updateDataSet() call, mostly to stop all the compiler warnings cause by the defines sprinkled around the original code.
These two pieces of code together have me reliably getting frequency data from accelerations between 0 and 500 Hz and with a FFT size up to 4096 bins.  This is not your fathers arduino, that is for sure!
Oh, and I used this project from SwitchScience as the base for all my work, but modified it heavily.  It is an interesting site and a fun read.  You probably need to install google translate in your browser, if you don't read Japanese, it works quite well.  I'm not going to publish my full project, I did that on company time, but the above code snippets should be more than enough to get you up to speed, and hopefully it will help someone else who also wants to dig into FFT on an embedded microprocessor in the future.
   FFT library
   Copyright (C) 2010 Didier Longueville
   Copyright (C) 2014 Enrique Condes
   This program is free software: you can redistribute it and/or modify
   it under the terms of the GNU General Public License as published by
   the Free Software Foundation, either version 3 of the License, or
   (at your option) any later version.
   This program is distributed in the hope that it will be useful,
   but WITHOUT ANY WARRANTY; without even the implied warranty of
   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
   GNU General Public License for more details.
   You should have received a copy of the GNU General Public License
   along with this program.  If not, see .
#ifndef arduinoFFT_h /* Prevent loading library twice */
#define arduinoFFT_h
#ifdef ARDUINO
#if ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h" /* This is where the standard Arduino code lies */
#endif
#else
#include <stdlib.h>
#include <stdio.h>
#ifdef __AVR__
#include <avr/io.h>
#include <avr/pgmspace.h>
#endif
#include <math.h>
#include "defs.h"
#include "types.h"
#endif
#define FFT_LIB_REV 0x14
/* Custom constants */
#define FFT_FORWARD 0x01
#define FFT_REVERSE 0x00
/* Windowing type */
#define FFT_WIN_TYP_RECTANGLE 0x00 /* rectangle (Box car) */
#define FFT_WIN_TYP_HAMMING 0x01 /* hamming */
#define FFT_WIN_TYP_HANN 0x02 /* hann */
#define FFT_WIN_TYP_TRIANGLE 0x03 /* triangle (Bartlett) */
#define FFT_WIN_TYP_NUTTALL 0x04 /* nuttall */
#define FFT_WIN_TYP_BLACKMAN 0x05 /* blackman */
#define FFT_WIN_TYP_BLACKMAN_NUTTALL 0x06 /* blackman nuttall */
#define FFT_WIN_TYP_BLACKMAN_HARRIS 0x07 /* blackman harris*/
#define FFT_WIN_TYP_FLT_TOP 0x08 /* flat top */
#define FFT_WIN_TYP_WELCH 0x09 /* welch */
/*Mathematial constants*/
#ifdef __AVR__
static const float _c1[]PROGMEM = {0.0000000000, 0.7071067812, 0.9238795325, 0.9807852804,
                                   0.9951847267, 0.9987954562, 0.9996988187, 0.9999247018,
                                   0.9999811753, 0.9999952938, 0.9999988235, 0.9999997059,
                                   0.9999999265, 0.9999999816, 0.9999999954, 0.9999999989,
                                   0.9999999997
static const float _c2[]PROGMEM = {1.0000000000, 0.7071067812, 0.3826834324, 0.1950903220,
                                   0.0980171403, 0.0490676743, 0.0245412285, 0.0122715383,
                                   0.0061358846, 0.0030679568, 0.0015339802, 0.0007669903,
                                   0.0003834952, 0.0001917476, 0.0000958738, 0.0000479369,
                                   0.0000239684
#endif
class arduinoFFT
  public:
    arduinoFFT(float *vReal, float *vImag, uint16_t samples, float samplingFrequency, float *windowWeighingFactors = NULL);
    ~arduinoFFT(void);
    void updateDataSet(float *vReal, float *vImag, uint16_t samples, float samplingFrequency, float *windowWeighingFactors = NULL);
    uint8_t Revision(void);
    void DCRemoval(float *vData, uint16_t samples);
    void ComplexToMagnitude();
    void Compute(uint8_t dir);
    void DCRemoval();
    float MajorPeak();
    void MajorPeak(float *f, float *v);
    void Windowing(uint8_t windowType, uint8_t dir, bool withCompensation = false);
    float MajorPeakParabola();
  private:
    uint16_t _samples;
    float _samplingFrequency;
    float *_vReal;
    float *_vImag;
    uint8_t _power;
    float *_windowWeighingFactors;
    uint8_t _weighingFactorsFFTWindow; // cache of windowType
    bool _weighingFactorsWithCompensation;
    bool _weighingFactorsComputed;
    constexpr static const float twoPi  =  6.28318531f;
    constexpr static const float fourPi = 12.56637061f;
    constexpr static const float sixPi  = 18.84955593f;
    static const float _WindowCompensationFactors[10];
    uint8_t Exponent(uint16_t value);
    void Swap(float *x, float *y);
    void Parabola(float x1, float y1, float x2, float y2, float x3, float y3, float *a, float *b, float *c);
arduinoFFT::arduinoFFT(float *vReal, float *vImag, uint16_t samples, float samplingFrequency, float *windowWeighingFactors)
  updateDataSet(vReal, vImag, samples, samplingFrequency, windowWeighingFactors);
arduinoFFT::~arduinoFFT(void)
  // Destructor
void arduinoFFT::updateDataSet(float *vReal, float *vImag, uint16_t samples, float samplingFrequency, float *windowWeighingFactors)
  this->_vReal = vReal;
  this->_vImag = vImag;
  this->_samples = samples;
  this->_samplingFrequency = samplingFrequency;
  this->_power = Exponent(samples);
  this->_windowWeighingFactors = windowWeighingFactors;
  this->_weighingFactorsWithCompensation = false;
  this->_weighingFactorsComputed = false;
uint8_t arduinoFFT::Revision(void)
  return (FFT_LIB_REV);
void arduinoFFT::Compute(uint8_t dir)
{ // Computes in-place complex-to-complex FFT /
  // Reverse bits /
  uint16_t j = 0;
  for (uint16_t i = 0; i < (this->_samples - 1); i++)
    if (i < j)
      Swap(&this->_vReal[i], &this->_vReal[j]);
      if (dir == FFT_REVERSE)
        Swap(&this->_vImag[i], &this->_vImag[j]);
    uint16_t k = (this->_samples >> 1);
    while (k <= j)
      j -= k;
      k >>= 1;
    j += k;
  // Compute the FFT  /
#ifdef __AVR__
  uint8_t index = 0;
#endif
  float c1 = -1.0;
  float c2 = 0.0;
  uint16_t l2 = 1;
  for (uint8_t l = 0; (l < this->_power); l++)
    uint16_t l1 = l2;
    l2 <<= 1;
    float u1 = 1.0;
    float u2 = 0.0;
    for (j = 0; j < l1; j++)
      for (uint16_t i = j; i < this->_samples; i += l2)
        uint16_t i1 = i + l1;
        float t1 = u1 * this->_vReal[i1] - u2 * this->_vImag[i1];
        float t2 = u1 * this->_vImag[i1] + u2 * this->_vReal[i1];
        this->_vReal[i1] = this->_vReal[i] - t1;
        this->_vImag[i1] = this->_vImag[i] - t2;
        this->_vReal[i] += t1;
        this->_vImag[i] += t2;
      float z = ((u1 * c1) - (u2 * c2));
      u2 = ((u1 * c2) + (u2 * c1));
      u1 = z;
#ifdef __AVR__
    c2 = pgm_read_float_near(&(_c2[index]));
    c1 = pgm_read_float_near(&(_c1[index]));
    index++;
#else
    c2 = sqrt((1.0 - c1) / 2.0);
    c1 = sqrt((1.0 + c1) / 2.0);
#endif
    if (dir == FFT_FORWARD) {
      c2 = -c2;
  // Scaling for reverse transform /
  if (dir != FFT_FORWARD) {
    for (uint16_t i = 0; i < this->_samples; i++) {
      this->_vReal[i] /= this->_samples;
      this->_vImag[i] /= this->_samples;
void arduinoFFT::ComplexToMagnitude()
  // vM is half the size of vReal and vImag
    this->_vReal[i] = sqrt(sq(this->_vReal[i]) + sq(this->_vImag[i])) * 2.0 / this->_samples;
void arduinoFFT::DCRemoval()
  // calculate the mean of vData
  float mean = 0;
    mean += this->_vReal[i];
  mean /= this->_samples;
  // Subtract the mean from vData
    this->_vReal[i] -= mean;
void arduinoFFT::DCRemoval(float *vData, uint16_t samples)
  float mean = 0;
  for (uint16_t i = 0; i < samples; i++)
    mean += vData[i];
  mean /= samples;
    vData[i] -= mean;
void arduinoFFT::Windowing(uint8_t windowType, uint8_t dir, bool withCompensation)
  // check if values are already pre-computed for the correct window type and compensation
  if (_windowWeighingFactors && _weighingFactorsComputed &&
      _weighingFactorsFFTWindow == windowType &&
      _weighingFactorsWithCompensation == withCompensation)
    // yes. values are precomputed
      for (uint_fast16_t i = 0; i < (this->_samples >> 1); i++)
        this->_vReal[i] *= _windowWeighingFactors[i];
        this->_vReal[this->_samples - (i + 1)] *= _windowWeighingFactors[i];
    else
        this->_vReal[i] /= _windowWeighingFactors[i];
        this->_vReal[this->_samples - (i + 1)] /= _windowWeighingFactors[i];
  else
    // no. values need to be pre-computed or applied
    // Weighing factors are computed once before multiple use of FFT
    // The weighing function is symmetric; half the weighs are recorded
    float samplesMinusOne = (float(this->_samples) - 1.0);
    float compensationFactor = _WindowCompensationFactors[windowType];
    for (uint16_t i = 0; i < (this->_samples >> 1); i++)
      float indexMinusOne = float(i);
      float ratio = (indexMinusOne / samplesMinusOne);
      float weighingFactor = 1.0;
      // Compute and record weighting factor
      switch (windowType)
        case FFT_WIN_TYP_RECTANGLE: // rectangle (box car)
          break;
        case FFT_WIN_TYP_HAMMING: // hamming
          weighingFactor = 0.54 - (0.46 * cos(twoPi * ratio));
          break;
        case FFT_WIN_TYP_HANN: // hann
          weighingFactor = 0.54 * (1.0 - cos(twoPi * ratio));
          break;
        case FFT_WIN_TYP_TRIANGLE: // triangle (Bartlett)
#if defined(ESP8266) || defined(ESP32)
          weighingFactor = 1.0 - ((2.0 * fabs(indexMinusOne - (samplesMinusOne / 2.0))) / samplesMinusOne);
#else
          weighingFactor = 1.0 - ((2.0 * abs(indexMinusOne - (samplesMinusOne / 2.0))) / samplesMinusOne);
#endif
          break;
        case FFT_WIN_TYP_NUTTALL: // nuttall
          weighingFactor = 0.355768 - (0.487396 * (cos(twoPi * ratio))) + (0.144232 * (cos(fourPi * ratio))) - (0.012604 * (cos(sixPi * ratio)));
          break;
        case FFT_WIN_TYP_BLACKMAN: // blackman
          weighingFactor = 0.42323 - (0.49755 * (cos(twoPi * ratio))) + (0.07922 * (cos(fourPi * ratio)));
          break;
        case FFT_WIN_TYP_BLACKMAN_NUTTALL: // blackman nuttall
          weighingFactor = 0.3635819 - (0.4891775 * (cos(twoPi * ratio))) + (0.1365995 * (cos(fourPi * ratio))) - (0.0106411 * (cos(sixPi * ratio)));
          break;
        case FFT_WIN_TYP_BLACKMAN_HARRIS: // blackman harris
          weighingFactor = 0.35875 - (0.48829 * (cos(twoPi * ratio))) + (0.14128 * (cos(fourPi * ratio))) - (0.01168 * (cos(sixPi * ratio)));
          break;
        case FFT_WIN_TYP_FLT_TOP: // flat top
          weighingFactor = 0.2810639 - (0.5208972 * cos(twoPi * ratio)) + (0.1980399 * cos(fourPi * ratio));
          break;
        case FFT_WIN_TYP_WELCH: // welch
          weighingFactor = 1.0 - sq((indexMinusOne - samplesMinusOne / 2.0) / (samplesMinusOne / 2.0));
          break;
      if (withCompensation)
        weighingFactor *= compensationFactor;
      if (_windowWeighingFactors)
        _windowWeighingFactors[i] = weighingFactor;
        this->_vReal[i] *= weighingFactor;
        this->_vReal[this->_samples - (i + 1)] *= weighingFactor;
      else
        this->_vReal[i] /= weighingFactor;
        this->_vReal[this->_samples - (i + 1)] /= weighingFactor;
      // mark cached values as pre-computed
      _weighingFactorsFFTWindow = windowType;
      _weighingFactorsWithCompensation = withCompensation;
      _weighingFactorsComputed = true;
float arduinoFFT::MajorPeak()
  float maxY = 0;
  uint16_t IndexOfMaxY = 0;
  //If sampling_frequency = 2 * max_frequency in signal,
  //value would be stored at position samples/2
  for (uint16_t i = 1; i < ((this->_samples >> 1) + 1); i++)
    if ((this->_vReal[i - 1] < this->_vReal[i]) && (this->_vReal[i] > this->_vReal[i + 1]))
      if (this->_vReal[i] > maxY)
        maxY = this->_vReal[i];
        IndexOfMaxY = i;
  float delta = 0.5 * ((this->_vReal[IndexOfMaxY - 1] - this->_vReal[IndexOfMaxY + 1]) / (this->_vReal[IndexOfMaxY - 1] - (2.0 * this->_vReal[IndexOfMaxY]) + this->_vReal[IndexOfMaxY + 1]));
  float interpolatedX = ((IndexOfMaxY + delta)  * this->_samplingFrequency) / (this->_samples - 1);
  if (IndexOfMaxY == (this->_samples >> 1)) //To improve calculation on edge values
    interpolatedX = ((IndexOfMaxY + delta)  * this->_samplingFrequency) / (this->_samples);
  // returned value: interpolated frequency peak apex
  return (interpolatedX);
void arduinoFFT::MajorPeak(float *f, float *v)
  float maxY = 0;
        IndexOfMaxY = i;
  *f = interpolatedX;
  *v = fabs(this->_vReal[IndexOfMaxY - 1] - (2.0 * this->_vReal[IndexOfMaxY]) + this->_vReal[IndexOfMaxY + 1]);
#else
  *v = abs(this->_vReal[IndexOfMaxY - 1] - (2.0 * this->_vReal[IndexOfMaxY]) + this->_vReal[IndexOfMaxY + 1]);
#endif
float arduinoFFT::MajorPeakParabola()
  float maxY = 0;
        IndexOfMaxY = i;
  float freq = 0;
  if ( IndexOfMaxY > 0 )
    // Assume the three points to be on a parabola
    float a, b, c;
    Parabola(IndexOfMaxY - 1, this->_vReal[IndexOfMaxY - 1], IndexOfMaxY, this->_vReal[IndexOfMaxY], IndexOfMaxY + 1, this->_vReal[IndexOfMaxY + 1], &a, &b, &c);
    // Peak is at the middle of the parabola
    float x = -b / (2 * a);
    // And magnitude is at the extrema of the parabola if you want It...
    // float y = a*x*x+b*x+c;
    // Convert to frequency
    freq = (x  * this->_samplingFrequency) / (this->_samples);
  return freq;
void arduinoFFT::Parabola(float x1, float y1, float x2, float y2, float x3, float y3, float *a, float *b, float *c)
  float reversed_denom = 1 / ((x1 - x2) * (x1 - x3) * (x2 - x3));
  *a = (x3 * (y2 - y1) + x2 * (y1 - y3) + x1 * (y3 - y2)) * reversed_denom;
  *b = (x3 * x3 * (y1 - y2) + x2 * x2 * (y3 - y1) + x1 * x1 * (y2 - y3)) * reversed_denom;
  *c = (x2 * x3 * (x2 - x3) * y1 + x3 * x1 * (x3 - x1) * y2 + x1 * x2 * (x1 - x2) * y3) * reversed_denom;
uint8_t arduinoFFT::Exponent(uint16_t value)
  // Calculates the base 2 logarithm of a value
  uint8_t result = 0;
  while (((value >> result) & 1) != 1) result++;
  return (result);
// Private functions
void arduinoFFT::Swap(float *x, float *y)
  float temp = *x;
  *x = *y;
  *y = temp;
const float arduinoFFT::_WindowCompensationFactors[10] =
  1.0000000000 * 2.0, // rectangle (Box car)
  1.8549343278 * 2.0, // hamming
  1.8554726898 * 2.0, // hann
  2.0039186079 * 2.0, // triangle (Bartlett)
  2.8163172034 * 2.0, // nuttall
  2.3673474360 * 2.0, // blackman
  2.7557840395 * 2.0, // blackman nuttall
  2.7929062517 * 2.0, // blackman harris
  3.5659039231 * 2.0, // flat top
  1.5029392863 * 2.0  // welch
#endif
Fausto Yair wrote 08/24/2023 at 05:43 point
Do you sell your code for vibration detection?
