I have now depotted the BMS of the G30 Battery, and found out that it uses a
STM8L151K6T6 for controlling the BMS and communication with the ESC.
I want to start a community based project to write a real Open Surce Firmware for the Ninebot G30(D) E Scooter
stm8l151c4-1851438.pdfThis is the datasheet for the BMS controller µC, its a 8 Bit STM8L151K6T6Adobe Portable Document Format - 1.64 MB - 12/02/2020 at 17:18 |
esc126_fulldump.binThis controls the ESC controller of the scooter, it is the most imporatant thing except the battery, the used µC is: STM32F103C8T6, same thing as the other files, we have to understand how this work to make it open source or write a open source firmware for the ESCoctet-stream - 128.00 kB - 12/01/2020 at 13:02 |
full_BLE555.binThe software that controls the dashboard, same game as with the BMS, someone with skills in reverse engineerin will have to take a look at it so we can reverse it to Source Code or write with the knowledge a new open version of the dashboardfirmwareoctet-stream - 256.00 kB - 12/01/2020 at 13:01 |
bms134_fulldump.binBMS Software, we will need to reverse it and understand how it works if we want to make a all Open Source Firmware we know now, that the used µC is a STM8L151K6T6octet-stream - 64.00 kB - 12/01/2020 at 12:59 |
