- Move ridge on upper shelf to go up? Remove ridge? - Check if 82" is too tall - Add top rail - Reduce width, recommended max span for 3/4" plywood is 30" (add steel angle rod to back?). Need some sort of support mechanism - Figure out how shelves will rotate? Maybe they don't rotate? Lazy susan bearing as possible option - Check what internal diameter of Susan bearing will be needed - Expand PC case to 24" deep (match Ellen's desk) and 4" tall? Or keep it 3.75" - How to stop table from rotating?- - How to add supports for weight of shelves? Need some sort of steel bar? - Estimated TDP is around 485W (ADL Intel cpu and 3070 GPU), how are we going to get rid of the heat
