cap.stl
End cap with opening for acrylic window, as used in the final project.
Standard Tesselated Geometry - 72.26 kB - 12/05/2020 at 03:09
Download
corner_jig.stl
Used to hold the 3 mm acrylic sheets at a perfect 90 degree angle while gluing. Optional, but highly recommended.
Standard Tesselated Geometry - 5.72 kB - 12/05/2020 at 03:49
Download
cap_solid.stl
Alternate end cap without acrylic window, will take longer to print.
Standard Tesselated Geometry - 35.54 kB - 12/05/2020 at 03:09
Download
cap.scad
Parametric OpenSCAD file to create custom end caps.
x-openscad - 1.22 kB - 12/05/2020 at 03:09
Download
