1. The article was first posted on Dec. 05, 2020.
2. Revised on Mar. 25, 2022
3. Revised on Mar. 18, 2025.
Corrected a typo in the assembly code list.
Added the latest version assembly code list 'COMMAND_TERMINAL-2_1_1.pdf' to the attached files.
4. Revised on Jun. 03, 2025.
Removed previous assembly code list 'COMMAND_TERMINAL-2_0_0.pdf' with erroneous description.
