First assembly !
A project log for Spine desk lamp
a project for my work-from-home desk, with CNC cut profiles, addressable LEDs, with tentacle kinematics
sebsplanesebsplane 01/27/2021 at 21:520 Comments
I managed to cut 21 profiles ( in 4 runs on the cnc )  and i couldn't help but try a dry fit with what i had on my hands :) :
the only problem  was that i had to re-drill every hole to make the bike shifter cable go though... I also understood why my plywood started to fell off : there is only a micron thick layer glued on every side! I though plywood was made of equally thick layers but this one is plated :( .
i used steel fishing line (rated 63kg, coated in plastic) for the actuation cables it looks lightweight and works well.
However i'm wondering how i will turn this bendy, twisty contraption into a sturdy lamp: i  expect to have at least a lateral rigidity so i can actuate it only longitudinally . I'm still missing some spacer in between and maybe i will have to glue them to avoid torsion. I'm also thinking of replacing the lateral cables by some thin piano wire to straighten/rigidify . The assembly also suffers from the fact that the bike cable looks permanently bent in some places despite me trying to straighten it with some weight...
here is a test with an addressable led strip in it driven by a wemos and the great https://github.com/FastLED/FastLED library :I don't know if it will make a great lamp but it is a really fun thing to build !
The movements looks really organic:
I will look into what i can do to improve the movements predictability but for now i'm really happy on how it came out !
