Atomic Synchronator => TicTacSync
Beyond '67 SMPTE timecode: YaLTC is a new GPS based AUX syncing track format for dual-system sound based on affordable hardware
This is a cheap hardware dongle to aid in automatically syncing audio and video you're shooting. Eh oui, yet another LTC... hence the name: YaLTC. It should interest scientists who need to timestamp data recordings within sub-millisecond precision and multicam /dual-system sound videographers - who don't want to fork 200 CAD for a syncing program, neither 270 CAD for each recording device to sync (cams, audio recorders) - who have encountered some limitations of their editing software "waveform analysis syncing". Maybe I'll eventually distribute pre-flashed kits on tindie (essentially off the shelves components). A GUI application is considered for non-dev users (a lot of videographers DONT have a running python installation). Wrapping synced material under OpenTimelineIO is explored. [EDIT]: "Les années ont passé" and the software side has metastasied and morphed into a Media Asset Management for movie making...
See the project New home
Project status: working. Audio clips are merged and synced to corresponding video, see this log.
Project Stage: alpha
I've implemented an audio sync track generator using the 1 PPS from a GPS receiver. Between each seconds the time of day is BFSK modulated into an audio signal and parsed in post-production by  tictacsync.py, merging sound clips with their corresponding video tracks (thanks to FFmpeg) and this, before importing into your NLE of choice.
Side Note: Someone more competent than me should have tackled this! I've NO formal compsci education except two programming introduction courses 40 years ago! (Pascal and Fortran) But here we go...
Pros and cons:
  • no jam sync required
  • no settings. Plug'n go, it is frame rate agnostic (DF, NDF? meh)
  • no drift in GNSS mode (it's atomic)
  • subframe precision (tests show files are synced within 83 μs, that's 0.003 frame!)
  • low cost (20-30 USD per device)
  • can be used with cameras lacking mic input (acoustic coupling was a pain in the ass to R&D, though)
  • more resilient than NLE waveform analysis
  • it's FOSS
but
  • some assembly required
  • not standard (it's a feature, not a bug)
  • adequate GPS signal strength needed for wireless mode  (not a problem for most residential buildings)
  • CLI only, for now
  • one guy in his basement project (hopefully not for long)
  • crappy code (but I'm working on it)
All three hard/soft components have been implemented and tested:
  • two hardware dongles (SAMD21 based)
  • firmware
  • post-production analysis desktop software (proof-of-concept version)
Here's the analysis results for two test files:
Watch here the first complete automated audio/video merge: Syncing in the kitchen. For multicam sync, I'll use Olive capacity to read OpenTimelinIO files.
  • 1 × a SAMD21 board eg Adafruit Feather M0 proto, 20 USD
  • 1 × a GPS module with 1PPS output eg Adafruit Feather Ultimate GPS 40 USD
  • 1 × a single supply opamp for mid-level reference aka virtual ground I'm using a LM358
  • 1 × Arduino IDE, python and FFmpeg installed
View all 26 project logs
View all instructions
zk0415004 wrote 12/13/2023 at 15:30 point
My cooperation with the project has been really beneficial to me. I'd want to share it with the CapCut apk mod team so they can read it and apply something new.
winfredp.rodriguez wrote 08/07/2023 at 06:17 point
Amazing analysis. I truly love it. I also want to use it for my website related to video enhancement. Here is the link: https://alightmoto.com/
alvipurvorex wrote 07/30/2023 at 16:00 point
My cooperation with the project has been really beneficial to me. I'd want to share it with the CapCut Pro team so they can read it and apply something new.
Sean McVeigh wrote 01/03/2021 at 22:25 point
Considering this is an indoor device, why not use a chip-scale atomic clock?
EDIT: never mind, thought the price had come down, although you could sell as pro product :D
Raymond Lutz wrote 01/03/2021 at 22:36 point
ah ah! You got me on that one! And I thought you were joking until I looked it up!!! Those devices DO exist!!!  But for now prohibitively onerous... https://www.mouser.ca/ProductDetail/Microchip-Technology/090-03240-001/?qs=w%2Fv1CP2dgqpPJJa0jwVC6w%3D%3D
Anyway, you would have the hassle to jam sync them before use... Also this GPS chipset works OK indoor, even in a modern building with a steel framing (but in a basement reception in spotty).
Sean McVeigh wrote 01/03/2021 at 22:47 point
Yeah I worked on one in grad school (modded as magnetometer): https://tf.nist.gov/general/pdf/2703.pdf
Sean McVeigh wrote 01/03/2021 at 22:51 point
Wait, I assumed you only need one clock source? Use Ethernet for sync to capture devices: https://en.wikipedia.org/wiki/Precision_Time_Protocol
This is the technique used for multi-AP clock sync for triangulation in indoor location, often using GPS as CLK source. Didn't look too carefully if the recent updates meet your timing requirements.
