Introduction
In this project, we’ll build an overcurrent protection device. Overcurrent protection is protection against excessive currents or current beyond the acceptable current rating of the device. To protect downstream loads, the point of overcurrent protection should occur at the FET switch.
An overcurrent protection device can be implemented using a GreenPAK™ SLG46116V chip. The SLG46116V includes a P-FET Power Switch designed for load switching applications. The P-FET Power Switch can be controlled internally via the ON digital input of the P-FET Power Switch component in GreenPAK Designer, allowing the user to generate integrated mixed-signal control circuits.
The P-FET Power Switch contains a 28.5mΩ RDSON, 1.25 A P-channel MOSFET with fixed slew rate control. The device has a built-in soft-start, which controls the output rise time. This minimizes inrush current when the switch is enabled.
For this implementation, the protected circuit is connected to the voltage supply via the SLG46116V chip P-FET. When the current in the protection circuit reaches the preset maximum current rating value, the GreenPAK device can almost instantly turn off the P-FET power switch and stop the flow of “overcurrent”.
Below we described steps needed to understand how the overcurrent protection device has been programmed. However, if you just want to get the result of programming, download GreenPAK software to view the already completed GreenPAK Design File. Plug the GreenPAK Development Kit to your computer and hit the program to design the device.
Circuit Design and Analysis
An overcurrent protection application circuit with the block diagram of the SLG46116V chip is shown in Figure 1, and the internal design of the chip is shown in Figure 2.
As seen in Figure 2, besides the P-FET switch, the design requires additional components, one ACMP, one 2-bit LUT and one DLY.
To use the ACMP in a GreenPAK design, the power up signal (PWR UP) needs to be active (HIGH). Before the power-up signal POR, the ACMP is powered down. Its output is low, the output of LUT2 is low, and the ON signal of P-FET is inactive. After the power-up signal POR, if the current does not exceed the rated limit, then the ON signal will be active (high) and the switch is closed providing the power supply to the connected circuit.
The overcurrent limit threshold can be programmed/designed by selection of external resistor R1 in Figure 1, which is connected between the protected circuit and GND, and by selection of the INVref value of ACMP, which has 24 internal reference sources (50 mV – 1200 mV) and VDD/3, VDD/4, PIN 4.
The current limit can be calculated as the IN- Vref divided by the external resistor R1. In this design example IN- is 50mV and R1 =0.2 Ω, thus the current limit is equal to 250 mA. If the current exceeds 250mA the output of ACMP is low, the ON signal is low (inactive) and the P-FET
switch is open, thus the overcurrent flow is interrupted.
Once the overcurrent problem has been interrupted, the delay time of DLY0 (adjustable) will define the recovery time after which the P-FET will switch into the “ON” position and the protected circuit will resume being powered. This can cause a continuous cycle of switching on and off the PFET if the overcurrent is not resolved.
The domain for VIN: 1.5 V to 5.0 V. When ON is configured to be controlled internally, PWR_SW_ON (PIN 4) is configured as Push-Pull output.
When VIN is not used in the same voltage domain as VDD, using a large pull-down resistor on PWR_SW_ON (PIN 4) is recommended to prevent current from flowing through the P-FET Power Switch while the device is not powered. Also, to prevent glitches at the output, it is recommended to connect at least 0.1 μF capacitor from VOUT pin to the GND.
Conclusion
An overcurrent protection device can be easily implemented using a GreenPAK3 that includes a PFET Power Switch. It has...
