Temperature Probe
A project log for THE GEM - 500W [Light&heatsource]
State of the art GROW RAYDIATOR [light/heatsource] w. current injection 40amp featuring CREE XLAMP
To obtain the best possible control of the LED´s, we need to measure the temperature as close as possible to the LED heat pad. This will be done using a classic E3D thermistor in a cartridge (https://e3d-online.com/products/thermistor-cartridge). The sensor is 15mm long with a 50mm cable w. a good secure connector.
