Controller design done
A project log for THE GEM - Smart LED Grow Lamp[Light&heatsource]
Max 85amp - featuring CREE X LAMP
juan-antonio-sren-epJuan-Antonio Søren E.P. 12/21/2020 at 23:380 Comments
Added 6amp MOSFET next to the TMC2209 stepper pins (A+/-B+/-), tied to ground. X
Added text rCAN next to CAN termination resistor. Note: The two end-nodes in a CAN network must be terminated with 120ohm resistor.
Added AP2161W (active low) to cut USB power when VIN is applied.
Ready for prototypes!
