Channeling
A project log for THE GEM - Smart LED Grow Lamp[Light&heatsource]
Max 85amp - featuring CREE X LAMP
juan-antonio-sren-epJuan-Antonio Søren E.P. 01/03/2021 at 14:290 Comments
To raise the light up into the enclosure, some sort of air channel is needed. This channel will also serve as mounting bracket for the wooden enclosure. On the LED side, the channel/bracket will provide mounting holes for wire shielding.
