After an unfortunate toe injury, the decision was made to install a very bright, removable light to try to improve the visibility of the path. A 60W LED bulb was converted to 8.2V 200mA.
Then a heat resistant mount was printed out of PETG.
The prolific jump in zip tie prices has led to string.
It was hard to make any conclusions in a parking lot. That was the last of the dry weather for 36 hours. The mane problem is without a reflector, it's very diffuse.
