We are currently developing a fun learning experience which requires students to build Among Us minigame/tasks in real life using a limited amount of loose and prebuilt parts.
We believe that building something which is fun and inherently rewarding plus testable, will leave students highly motivated for more.
Currently the project is in a small research phase which will select the mini games suitable to be made with a minimum of parts and easy mechanics. The used parts should be as simple as possible.
The projects should otherwise be able to communicate their status and receive reset commands through MQTT.
Any help with the project is much appreciated!
Components
1×
ESP32 (Lolin D32)
WiFi Devboards compatible with the Arduino Framework
