Gen2 Mold - Testrun with PE and ABS
A project log for Making Plates out of Recycling Material
We run a Precious Plastic Workspace and want to expand our abilities to process plastic. This project is about making plastic sheets.
devlabnrwDevLab.nrw 01/29/2021 at 17:550 Comments
The Gen2 Form in combination with slicone spray works quite good, so I tested some more materials with it. As a result, ABS (black) and PE (green) worked well. Although the PE was melted the second time because I used cuttetd nIO Plates from the Gen1 trials
