Meeting with Reiner and Anoop -
01/13/2021 at 21:24 • 0 comments-Discussed using Lidar, sticking with APRIL tag
-able to use rviz remotely
Got April Tag detector to work - January 13th 2020
01/13/2021 at 21:24 • 0 comments-message was AprilTagDetectorArray
Build issues, ended up rebuilding librealsense from source -
01/13/2021 at 21:24 • 0 commentsBuild issues, ended up rebuilding librealsense from source -
Researching Tag Detection - January 10th 2021
01/13/2021 at 21:23 • 0 commentsI decided to switch from using QR codes to April Tags for the pose localization. This seems to be the Industry standard. I am currently tinkering with ArUco for image processing.
Did a great job of explaining the basics: https://www.youtube.com/watch?v=k8ZSzofAKTk
How robot will localize on tags -
01/13/2021 at 21:23 • 0 comments-used QR codes at this point
Tinkering with ROS, able to user terminal only on AGV -
01/13/2021 at 21:23 • 0 commentsTinkering with ROS, able to user terminal only on AGV -
Cable Management (Toggle Switch, cable track) -
01/13/2021 at 21:22 • 0 commentsCable Management (Toggle Switch, cable track) -
Mounted limit switch -
01/13/2021 at 21:22 • 0 commentsMounted limit switch -
Did keyboard control - December 28th 2020
