Clap Switch with the help of Arduino
In this, we have used clap sound and MIC to sense the sound which will turn on and off the device as a switch
0 followers
The project describes how we can use clap sound and MIC to sense the sound which will turn on and off the device as a switch.
About Project
Basically, a microphone is a sound sensing transducer, which primarily transforms sound energy into electrical energy, so with the help of this sensor, we have to sound as a changing voltage.
Working is followed basically in four ways such as: Filtration, Amplification, Analog-digital conversion and programming to toggle the LED.
Whenever there is sound, the MIC strikes it up and transforms it into voltage, direct to the magnitude of sound. So for a higher sound, we have a greater value and for the lower sound, we have a deeper value. This value is first filled to the High Pass Filter for the process of filtration.
Then this refined value is filled to the transistor for amplification and the transistor gives the amplified output at the collector. This collector signal is supplied to the ADC0 channel of the UNO, for Analog to Digital conversion.
  • 1 × Arduino Uno
  • 1 × Microphone Breakout
  • 1 × General Purpose Transistor NPN
  • 2 × Capacitor 100 nF
  • 2 × Capacitor 100 µF
View all 9 components
  • 1
    Run a Program
    const int analogInPin = A0; // Analog input pin 0
    int sensorValue = 0;
    void setup()
    DDRD = 0xFF;
    void loop()
    sensorValue = analogRead(analogInPin); //read ADC value on channel 0
    if(sensorValue>60)
    PORTD ^=(1<
View all instructions
