Updated CS42448 PCB
A project log for Dual Interleaved CS42448 Chip
16 Audio In & 16 Audio Out using only 5 pins
paul-stoffregenPaul Stoffregen 12/30/2020 at 12:350 Comments
Created an updated CS42448 board with small improvements and a header to connect to this interleaved TDM experiment.
https://hackaday.io/project/2984-teensy-audio-library/log/187557-updated-cs42448-pcb-for-teensy-4x
