First complete unit
A project log for Open Flow Meter
An Arduino powered flow-meter for use in geography river studies and environmental monitoring projects
ebenEben 12/24/2020 at 15:030 Comments
Here is the first fully assembled unit:
It features an: on/off switch, aviation connector, rechargeable battery, configurable intervals for taking speed tests and has a quick detach system from the ranging poll (this means we can carry less on field trips by using the range poll to hold the flow meter).
