The first batch of Satrans are on their way to the very first customers and I am working hard to speed up production so even more can enjoy the tech.
Sand casting has proven the greatest challenge which takes up a lot of production time. My first 3D-printed original patterns worked but were time-consuming and didnt last more than 10-20 uses. So this time I am trying something new - "cope and drag patterns".
This is a two-part original made out of MDF-board, 3D-printed parts, glue, spray filler and a few coats of heat-tolerant epoxy paint on top. When you cast a lot the petrobond sand will get quite hot and can damage the patterns, so epoxy should give some extra protection. If they hold up for 50 uses or more I would be happy, otherwise I need to step up the game even further with fiberglass-patterns.
