Time to test the firmware
A project log for SATRAN - Satellite Tracking Antenna
Wifi-controlled, azimuth/elevation antenna rotator.
daniel-nikolajsenDaniel Nikolajsen 01/13/2021 at 19:530 Comments
The very first prototype circuit board has been soldered together, and the first trials have worked perfectly!
However, there are a lot of features left to code for the "firmware". But as of now it can create a wifi access point with a setup page, and then store your wifi credentials and run a web server on your local wifi. Also it can turn two stepper motors without any hickups, but I couldnt try the limit switches today since i was missing some resistors.
All in all, everything is going according to schedule...
