The heat is on
A project log for SATRAN - Satellite Tracking Antenna
Wifi-controlled, azimuth/elevation antenna rotator.
daniel-nikolajsenDaniel Nikolajsen 05/05/2022 at 20:050 Comments
Finally the furnace is working, reaching up to 800 celcius which is enough for melting aluminum. But I wish I used another kind of fire brick, because the chamotte-stones take a lot of energy to warm up. But I can replace them later. Now its time to produce some more Satrans... wohoo!
