L071_serialLoopBack.inoExample file showing use of HardwareSerial to enable serial communications.ino - 975.00 bytes - 09/20/2023 at 00:50 |
tDuino2.zipRevised version of files to add tArmDuino to the Arduino IDE. Works with STM version 2.6.0.Zip Archive - 11.19 kB - 09/19/2023 at 20:43 |
2x3_spacer.stlSpacer or frame for the uploading clip. Ready to slice.sla - 20.20 kB - 01/13/2021 at 05:35 |
uProg_2x3-F.Paste.gtpSolder paste stencil for the clip.gtp - 479.00 bytes - 01/13/2021 at 05:34 |
uProc_2x3.zipClip gerbers ready to order boards.Zip Archive - 4.12 kB - 01/13/2021 at 05:34 |
uProg_2x3-cache.libClip KiCAD library file.lib - 789.00 bytes - 01/13/2021 at 05:34 |
uProg_2x3.schClip KiCAD schematic.x-kicad-schematic - 2.13 kB - 01/13/2021 at 05:34 |
uProg_2x3.proClip KiCAD project file.x-kicad-project - 661.00 bytes - 01/13/2021 at 05:34 |
uProg_2x3.kicad_pcbClip KiCAD pcb file.x-kicad-pcb - 8.26 kB - 01/13/2021 at 05:34 |
L071_SPI_LoopBack.inoSPI loop back that works showing the necessary modifications.ino - 779.00 bytes - 01/06/2021 at 04:35 |
L071_SPI_LoopBack1.inoSPI loop back example that fails. The original version.ino - 696.00 bytes - 01/06/2021 at 04:35 |
L071_ssd1306_MenuDemo.inoArduino sketch to demonstrate the use of the SSD1306 OLED display.ino - 3.51 kB - 01/04/2021 at 01:11 |
STML0_Small32-F.Paste.gbrDebug version - Paste stencil gerberx-gerber - 9.88 kB - 12/28/2020 at 23:20 |
STML0_Small32.zipDebug version - Gerbers for PCBZip Archive - 45.24 kB - 12/28/2020 at 23:20 |
STML0_Small32-cache.libDebug version - KiCAD library cachelib - 3.80 kB - 12/28/2020 at 23:20 |
STML0_Small32.kicad_pcbDebug version - KiCAD PCB filex-kicad-pcb - 62.22 kB - 12/28/2020 at 23:20 |
STML0_Small32.schDebug version - KiCAD schematic filex-kicad-schematic - 9.64 kB - 12/28/2020 at 23:20 |
STML0_Small32.proDebug version - KiCAD Project filex-kicad-project - 842.00 bytes - 12/28/2020 at 23:19 |
STML0_Tiny32-F.Paste.gbrtArmDuino version - Paste Stencil gerberx-gerber - 2.34 kB - 12/28/2020 at 23:16 |
STML0_Tiny32.ziptArmDuino version - Gerbers for PCBZip Archive - 32.38 kB - 12/28/2020 at 23:15 |
STML0_Tiny32-cache.libtArmDuino version - KiCAD library cachelib - 5.21 kB - 12/28/2020 at 23:15 |
STML0_Tiny32.kicad_pcbtArmDuino version - KiCAD PCB filex-kicad-pcb - 59.80 kB - 12/28/2020 at 23:15 |
STML0_Tiny32.schtArmDuino version - KiCAD Schematic filex-kicad-schematic - 10.17 kB - 12/28/2020 at 23:15 |
STML0_Tiny32.protArmDuino version - KiCAD Project filex-kicad-project - 881.00 bytes - 12/28/2020 at 23:15 |
