Project development completed
A project log for Video trigger generator for oscilloscope
This project generates a trigger output for an oscilloscope. It can select which line we want of the video signal (NTSC only).
Jacques PelletierJacques Pelletier 01/02/2021 at 22:260 Comments
I finally made this project work after much head scratching.
The result is a stable trigger output for any scope. This version uses common push button switches.
The design could use capacitive switches instead with the Q switch library. To be tried next.
