I started this one on a whim with winter break coming and it all kind of came together. What's currently up there now is the beta version but it is going to be upgraded soon. Ever since watching Johnny Mnemonic as a kid the internet headset he uses has fascinated me. Now that the tech has caught up to the present I thought it was finally time to make one.
jordanbrandes
I purchased the headset from Walmart. I have a large head and I am super duper near-sighted (myopic) so one thing I noticed almost immediately is that this headset can't be worn with glasses on (unless you are good with a Dremel and can widen the eyepiece area carefully and re-pad it)
I also went with a different screen that has HDMI in and audio out on the board. I have ADD and would like to see if this could help me focus. Rather than being able to mount the pi on the back of the screen, my plan is to just mount the screen to the goggles and then run the cables for power and video signal over the central headstrap into a pack I can wear on my back or chest. I know it gets a bit messier this way, and I'm still not sure this is what I will ultimately do, but it'll give me the option to plug it into a laptop or other video source. What you did with the pi though is great, it adds almost no extra weight. The tradeoff is that the USB ports could be hard to get to and/or you don't want cables hanging as much as you can avoid it.
