K3lso Quadruped
K3lso is a quadruped robot similar to MIT mini cheetah and MIT Cheetah 3.
More to come later on. Build in progress.
 Follow me on twitter for frequently updates: r_frojd
Cheers
  • Head head head
    Robin Fröjd12 hours ago 0 comments
    Gripper planning, I think a flex joint is needed which lets the gripper go up when on the ground.
    Each claw is planned for be double jointed. The most suited micro linear actuators I could find was the LASF16-104D. Which also provides force feedback.
    They have the follow specs:
    #k3lso #quad #quadruped #robtics #fusion360 #ros #mjbots #tmotor #prototype #UPXtreme #MIT #cheetah https://t.co/dem0ickzV0
  • New head design in progress
    Robin Fröjd2 days ago 0 comments
    K3lso wants to stand out from the dog herd!
    Check it out and give me your comments!
    And yes I am planning for a Jaw gripper. :-)
  • depthai
    So. I have ordered two kits from Luxonis  the DepthAI: USB3C with Modular Cameras. Which I will test.
    I also have adjust the side cover to fit the cameras in a nice way (Removing the "spot" look)
    The camera covers can be removed  with the USB3C and the modular cameras. One of the main reasons I took this path, is quite simple. I can more easily integrate these into the covers. Changing lenses and adjusting the baseline is also better.
    We will see how they work out! :)
  • On the desk
    Robin Fröjd01/14/2021 at 18:02 2 comments
    so last days I haven't done much. Cleaning up k3lsos workbench and added a monitor
    I have also been working to finalize the mid covers. I would say I am about 90% done with the mid-covers. I will continue to work on them tonight
  • Sandy
    Robin Fröjd01/12/2021 at 22:46 0 comments
    So I think it's decided. I don't know why I didn't think about it before. Since this build is named after my deceased pug. This is the color it should have!
  • Stand is 90% done
    Robin Fröjd01/12/2021 at 20:10 0 comments
    So I just got the parts for the robot stand today. Printed some mounts that wraps around the hip actuators. Which means I can just lift it on the stand and it sits there VERY firmly.
    Perfect. Now it will be a bit easier to work on it :)
  • Black or Green?
    Robin Fröjd01/12/2021 at 00:19 2 comments
    having hard time deciding on the final color scheme. They both looks good and both have +-
    We shall see. What do you guys think?
  • Camera cover
    Robin Fröjd01/10/2021 at 22:52 0 comments
    Tonight's work: camera cover for the #realsense #d455 also added a few air ducts. Still in progress! :)
  • More assembly testing
    Robin Fröjd01/09/2021 at 12:59 0 comments
    awaiting parts for the robot stand. Its a bit hard to move this around as it is. So in meanwhile I am just doing some more assembly testing
  • Test assembly
    Robin Fröjd01/08/2021 at 16:16 2 comments
    a quick test assembly to confirm all parts
View all 55 project logs
Allen-Song-shannon wrote 3 days ago point
Is this puppy ready for sale? I like the way he looks, but I don't know what his function is. Can it be compared with Boston?
Robin Fröjd wrote 11 hours ago point
ready for sale? No its a hobby project. :)
Vuong Nguyen wrote 6 days ago point
This is awesome. Do you plan any AI models to use for navigation. What chip do you use for the "brain" part?
Thanks! I am not quite there yet. :) for brain UP Xtreme i7C1-8565U with UP Vision Plus X ( 3x Myriad X)
kdomanski12 wrote 01/12/2021 at 19:16 point
Great project. Could you tell me how do you want to manufacture the cover of the robot. It will not be bent sheet metal, am I right?
Robin Fröjd wrote 01/12/2021 at 20:27 point
Thanks! They will SLA printed. you are correct no sheet metal :)
George Hartt wrote 01/11/2021 at 11:57 point
What rubber did you use for casting the rubber? Did you use any mould release for the 3dp moulds? Awesome work!
Robin Fröjd wrote 01/12/2021 at 20:23 point
Vacuum die casting. Rubber  Hardness 60! Thanks!
George Hartt wrote 01/14/2021 at 17:35 point
What sort of Rubber product did you use for casting? Any brand?
3gfisch wrote 01/10/2021 at 21:33 point
wow this is awesome and beautiful, i like the evil black and red look even more then the boston dynamics look
Robin Fröjd wrote 01/12/2021 at 20:12 point
Many thanks for the kind Words! :)
Jay Polo wrote 01/10/2021 at 18:02 point
I love it!  Curious, what's your estimated build budget?
Thanks! I do not have these numbers yet.
Chris Bruner wrote 01/06/2021 at 17:43 point
What motors are you planning on using?
Robin Fröjd wrote 01/06/2021 at 17:56 point
AK10-9
David wrote 01/06/2021 at 17:38 point
Great project! Where is the video where it get kicked around by humans and then hunt them down? I guess the software and movement part is actually the hardest.
Robin Fröjd wrote 01/06/2021 at 17:57 point
haha thanks! It will run cheetah mpc controller to start.
Sajiv Shah wrote 01/06/2021 at 07:21 point
This is incredible stuff not sure why it doesn't have thousands of followers. Love seeing the updates!
dhruv wadhwa wrote 01/06/2021 at 08:40 point
Yeahh
Robin Fröjd wrote 01/06/2021 at 17:58 point
thanks 😊
Mike Szczys wrote 12/30/2020 at 23:25 point
Whoa, incredible! Of course the milled parts are spectacular, but the rubber parts that you cast look amazing. Looking forward to following along on what is certainly a long journey ahead ;-)
Robin Fröjd wrote 12/31/2020 at 12:28 point
Thanks Mike! :-)
GekkePrutser wrote 12/29/2020 at 23:22 point
This is so amazing!!
Super professional.
Robin Fröjd wrote 12/29/2020 at 23:52 point
Thanks 😊
Larock1234 wrote 12/29/2020 at 13:15 point
This project and your progress is incredible! Are you working full-time on this project? Or how do you realize this complex project this fast?
Robin Fröjd wrote 12/29/2020 at 15:15 point
Thanks for the kind Words! Nah. only on my spare time as a hobby ( a few hours every night) :)
Nickle the Pickle wrote 12/28/2020 at 20:50 point
This is bad-fucking-ass!
Robin Fröjd wrote 12/28/2020 at 21:48 point
Thanks! exactly what I was aiming for :)
Charles Galambos wrote 12/28/2020 at 15:09 point
Great looking build!    Have you got any ideas about the software you are going to use to control it?
Robin Fröjd wrote 12/28/2020 at 16:03 point
thanks! Yes to start cheetah mpc controller
https://youtu.be/UE5tCgVueE0
Kosma wrote 12/28/2020 at 11:34 point
why is that necessary for who?
Robin Fröjd wrote 12/28/2020 at 12:04 point
Please clarify your question?
Ivan Stepaniuk wrote 12/28/2020 at 11:28 point
Impressive work. Is this a commercial endeavour, is it open source? I can't even imagine how many hours of design and CAD work this took. Following!
At the moment only for fun :) But I guess it will be open source in the end. ;) Thanks!
Robin Fröjd wrote 12/27/2020 at 10:13 point
help you with what?
