K3lso Quadruped
K3lso is a quadruped robot similar to MIT mini cheetah and MIT Cheetah 3.
More to come later on. Build in progress.
 Follow me on twitter for frequently updates: r_frojd
Cheers
  • Head head head
    Robin Fröjd12 hours ago 0 comments
    Gripper planning, I think a flex joint is needed which lets the gripper go up when on the ground.
    Each claw is planned for be double jointed. The most suited micro linear actuators I could find was the LASF16-104D. Which also provides force feedback.
    They have the follow specs:
    #k3lso #quad #quadruped #robtics #fusion360 #ros #mjbots #tmotor #prototype #UPXtreme #MIT #cheetah https://t.co/dem0ickzV0
  • New head design in progress
    Robin Fröjd2 days ago 0 comments
    K3lso wants to stand out from the dog herd!
    Check it out and give me your comments!
    And yes I am planning for a Jaw gripper. :-)
  • depthai
    So. I have ordered two kits from Luxonis  the DepthAI: USB3C with Modular Cameras. Which I will test.
    I also have adjust the side cover to fit the cameras in a nice way (Removing the "spot" look)
    The camera covers can be removed  with the USB3C and the modular cameras. One of the main reasons I took this path, is quite simple. I can more easily integrate these into the covers. Changing lenses and adjusting the baseline is also better.
    We will see how they work out! :)
  • On the desk
    Robin Fröjd01/14/2021 at 18:02 2 comments
    so last days I haven't done much. Cleaning up k3lsos workbench and added a monitor
    I have also been working to finalize the mid covers. I would say I am about 90% done with the mid-covers. I will continue to work on them tonight
  • Sandy
    Robin Fröjd01/12/2021 at 22:46 0 comments
    So I think it's decided. I don't know why I didn't think about it before. Since this build is named after my deceased pug. This is the color it should have!
  • Stand is 90% done
    Robin Fröjd01/12/2021 at 20:10 0 comments
    So I just got the parts for the robot stand today. Printed some mounts that wraps around the hip actuators. Which means I can just lift it on the stand and it sits there VERY firmly.
    Perfect. Now it will be a bit easier to work on it :)
  • Black or Green?
    Robin Fröjd01/12/2021 at 00:19 2 comments
    having hard time deciding on the final color scheme. They both looks good and both have +-
    We shall see. What do you guys think?
  • Camera cover
    Robin Fröjd01/10/2021 at 22:52 0 comments
    Tonight's work: camera cover for the #realsense #d455 also added a few air ducts. Still in progress! :)
  • More assembly testing
    Robin Fröjd01/09/2021 at 12:59 0 comments
    awaiting parts for the robot stand. Its a bit hard to move this around as it is. So in meanwhile I am just doing some more assembly testing
  • Test assembly
    Robin Fröjd01/08/2021 at 16:16 2 comments
    a quick test assembly to confirm all parts
View all 55 project logs
Allen-Song-shannon wrote 3 days ago point
Is this puppy ready for sale? I like the way he looks, but I don't know what his function is. Can it be compared with Boston?
Robin Fröjd wrote 12 hours ago point
ready for sale? No its a hobby project. :)
Vuong Nguyen wrote 6 days ago point
This is awesome. Do you plan any AI models to use for navigation. What chip do you use for the "brain" part?
Robin Fröjd wrote 11 hours ago point
Thanks! I am not quite there yet. :) for brain UP Xtreme i7C1-8565U with UP Vision Plus X ( 3x Myriad X)
kdomanski12 wrote 01/12/2021 at 19:16 point
Great project. Could you tell me how do you want to manufacture the cover of the robot. It will not be bent sheet metal, am I right?
Robin Fröjd wrote 01/12/2021 at 20:27 point
Thanks! They will SLA printed. you are correct no sheet metal :)
George Hartt wrote 01/11/2021 at 11:57 point
What rubber did you use for casting the rubber? Did you use any mould release for the 3dp moulds? Awesome work!
Robin Fröjd wrote 01/12/2021 at 20:23 point
Vacuum die casting. Rubber  Hardness 60! Thanks!
George Hartt wrote 01/14/2021 at 17:35 point
What sort of Rubber product did you use for casting? Any brand?
3gfisch wrote 01/10/2021 at 21:33 point
wow this is awesome and beautiful, i like the evil black and red look even more then the boston dynamics look
Robin Fröjd wrote 01/12/2021 at 20:12 point
Many thanks for the kind Words! :)
Jay Polo wrote 01/10/2021 at 18:02 point
I love it!  Curious, what's your estimated build budget?
Thanks! I do not have these numbers yet.
Chris Bruner wrote 01/06/2021 at 17:43 point
What motors are you planning on using?
Robin Fröjd wrote 01/06/2021 at 17:56 point
AK10-9
David wrote 01/06/2021 at 17:38 point
Great project! Where is the video where it get kicked around by humans and then hunt them down? I guess the software and movement part is actually the hardest.
Robin Fröjd wrote 01/06/2021 at 17:57 point
haha thanks! It will run cheetah mpc controller to start.
Sajiv Shah wrote 01/06/2021 at 07:21 point
This is incredible stuff not sure why it doesn't have thousands of followers. Love seeing the updates!
dhruv wadhwa wrote 01/06/2021 at 08:40 point
Yeahh
Robin Fröjd wrote 01/06/2021 at 17:58 point
thanks 😊
Mike Szczys wrote 12/30/2020 at 23:25 point
Whoa, incredible! Of course the milled parts are spectacular, but the rubber parts that you cast look amazing. Looking forward to following along on what is certainly a long journey ahead ;-)
Robin Fröjd wrote 12/31/2020 at 12:28 point
Thanks Mike! :-)
GekkePrutser wrote 12/29/2020 at 23:22 point
This is so amazing!!
Super professional.
Robin Fröjd wrote 12/29/2020 at 23:52 point
Thanks 😊
Larock1234 wrote 12/29/2020 at 13:15 point
This project and your progress is incredible! Are you working full-time on this project? Or how do you realize this complex project this fast?
Robin Fröjd wrote 12/29/2020 at 15:15 point
Thanks for the kind Words! Nah. only on my spare time as a hobby ( a few hours every night) :)
Nickle the Pickle wrote 12/28/2020 at 20:50 point
This is bad-fucking-ass!
Robin Fröjd wrote 12/28/2020 at 21:48 point
Thanks! exactly what I was aiming for :)
Charles Galambos wrote 12/28/2020 at 15:09 point
Great looking build!    Have you got any ideas about the software you are going to use to control it?
Robin Fröjd wrote 12/28/2020 at 16:03 point
thanks! Yes to start cheetah mpc controller
https://youtu.be/UE5tCgVueE0
Kosma wrote 12/28/2020 at 11:34 point
why is that necessary for who?
Robin Fröjd wrote 12/28/2020 at 12:04 point
Please clarify your question?
Ivan Stepaniuk wrote 12/28/2020 at 11:28 point
Impressive work. Is this a commercial endeavour, is it open source? I can't even imagine how many hours of design and CAD work this took. Following!
At the moment only for fun :) But I guess it will be open source in the end. ;) Thanks!
Robin Fröjd wrote 12/27/2020 at 10:13 point
help you with what?
