More to come later on. Build in progress.
Follow me on twitter for frequently updates: r_frojd
Cheers
K3lso is a quadruped robot similar to MIT mini cheetah and MIT Cheetah 3.
Cheers
A very quick draft of half the back cover. Design purposes only.
#k3lso #quadruped #quad #3Dprinting #raise3d #robotics #bldc #ros
A very rough first print for half top cover. Needed something to touch and visualize IRL before going further with covers. And No I will not use home 3D printed covers.
#k3lso #quadruped #quad #ros #robotics #UPXtreme #ROS #unitree #bostondynamics #laikago #mjbots https://t.co/rIo9h7ytxO
Test assembly of CF leg with new lower design/foot. Everything fits perfectly! Happy with the more rough looks!
Weight data comparison:
Upper:
CF = 219g
7075 = 315g
reduction 43%
Lower:
CF = 185g
7075 = 254g
reduction 37%
Motor mount:
CF = 99g
7075 = 145g
reduction 46%
#k3lso #quad #quadruped #UPXtreme #cnc #robotics #ros #design #fusion360 #carbon #leggedrobotics @UPbridge_gap
New parts. One full set of CF legs for the robot and also a set of the new lower leg design in 7075.
The foot mold fitted perfectly! The CF legs are about 38% lighter then 7075.
Switch running #Ubuntu #ros master/slave with an #UPXtreme and #realsense #d435 streaming video to switch and also running #champ
#k3lso #quadruped #quad #robotics https://t.co/x4me8S2Ly3
Switch running #Ubuntu and #ROS #Melodic trying #champ package by @joemeno visualized in #Rviz
Managed to buy a unpatched switch yesterday:) Plan is to run L4T Ubuntu and it should be #K3lso Quadruped remote control. It will suffice for a start.
#robotics #nvidia #quadruped #quad #ros
What a pity! Many of my friends are interested in four-legged robots, but they just don't want to make one themselves, so I'd like to ask if you have any plans to sell it.so I want to ask if you have any plans to sell it. And I have a question, which way is your robot controlled, and how is the control effect?
This is awesome. Do you plan any AI models to use for navigation. What chip do you use for the "brain" part?
Thanks! I am not quite there yet. :) for brain UP Xtreme i7C1-8565U with UP Vision Plus X ( 3x Myriad X)
Great project. Could you tell me how do you want to manufacture the cover of the robot. It will not be bent sheet metal, am I right?
Thanks! They will SLA printed. you are correct no sheet metal :)
What rubber did you use for casting the rubber? Did you use any mould release for the 3dp moulds? Awesome work!
What sort of Rubber product did you use for casting? Any brand?
Do you have access to all this stuff at work or do you know any reasonable producer here in sweden? I've found that all plastic producer wants insane prices for the most simple parts, got a quote on 85tkr the last day for just one mold.
wow this is awesome and beautiful, i like the evil black and red look even more then the boston dynamics look
Great project! Where is the video where it get kicked around by humans and then hunt them down? I guess the software and movement part is actually the hardest.
haha thanks! It will run cheetah mpc controller to start.
This is incredible stuff not sure why it doesn't have thousands of followers. Love seeing the updates!
Whoa, incredible! Of course the milled parts are spectacular, but the rubber parts that you cast look amazing. Looking forward to following along on what is certainly a long journey ahead ;-)
This project and your progress is incredible! Are you working full-time on this project? Or how do you realize this complex project this fast?
Thanks for the kind Words! Nah. only on my spare time as a hobby ( a few hours every night) :)
Great looking build! Have you got any ideas about the software you are going to use to control it?
Impressive work. Is this a commercial endeavour, is it open source? I can't even imagine how many hours of design and CAD work this took. Following!
At the moment only for fun :) But I guess it will be open source in the end. ;) Thanks!
Is this puppy ready for sale? I like the way he looks, but I don't know what his function is. Can it be compared with Boston?
