Range of motion test for leg
A project log for K3lso Quadruped
K3lso is a quadruped robot similar to MIT mini cheetah and MIT Cheetah 3.
robin-frjdRobin Fröjd 12/23/2020 at 19:000 Comments
Full inverted low leg possible within workspace with max 50mm inline tension turnbuckle. The kink on the lower leg limits the degrees on inverted side.
