Low leg design
A project log for K3lso Quadruped
K3lso is a quadruped robot similar to MIT mini cheetah and MIT Cheetah 3.
robin-frjdRobin Fröjd 12/31/2020 at 13:040 Comments
So for revision two on the lower legs I adding a smoother foot transition. The transition and the design itself is inspired by  BD Spot.
My first design was a bit to long. So next version is 275mm foot included. This also saves a bit of torque.
When adjusting the size to ~ 275mm the Strength analysis also looks much better.
First prototype of the legs is all milled in ALU 7075. For second revison I might go down milling in CF. lets see.
Size comparison:
Strength analysis:
Foot design:
The section view of the foot (not ready yet). It wraps around the low leg and are molded with rubber 60A. We shall see what hardness I end up with.
Design check:
