SpotPico
A nano-sized take on the Spotmicro quadruped robot
A much smaller version of the popular Spotmicro robot.
The goal was to design and build a smaller Spotmicro robot. The Spotmicro was originally created by Deok-yeon Kim (KDY0523 on Thingiverse). The SpotPico is a much smaller version of that robot. It uses smaller and lighter 5g servos and is controlled by a TinyPICO NANO.
  • 1 × TinyPICO NANO World's smallest, fully-featured ESP32 development board.
  • 12 × JX DHV56MG or Turnigy TGY-D56MG servo Coreless digital, metal gear, high-voltage micro servo. The two models are identical as far as I can tell.
  • 1 × Servo battery management board ANMBEST 2PCS 2A 5V Charge Discharge Integrated Module 3.7 4.2V 18650 Lithium Battery PCB BMS Protection Board Upgraded.
  • 1 × IMU GY-25 MPU-6050 Sensor Module
  • 1 × TinyPICO NANO Battery 721417 3.7V 110mAh 25C LiPo Battery
View all 10 components
  • Final design
    Ayo Ajayi01/08/2021 at 02:39 0 comments
    The final update design has been partially assembled and a USB C connector had been used in place of the micro USB connector.
    The tiny 0.49" OLED display has also been fitted and all wiring has been done.
    Will be powering up the TinyPICO NANO next to make sure everything functions as it should
View project log
