Final design
A project log for SpotPico
A nano-sized take on the Spotmicro quadruped robot
ayo-ajayiAyo Ajayi 01/08/2021 at 02:390 Comments
The final update design has been partially assembled and a USB C connector had been used in place of the micro USB connector.
The tiny 0.49" OLED display has also been fitted and all wiring has been done.
Will be powering up the TinyPICO NANO next to make sure everything functions as it should
