Column
A project log for CNC machine V3: Mill
The third version of my CNC machine I’m making, all the pervious ones had serious issues with stability.
loufourmountainsloufourmountains 12/27/2020 at 11:110 Comments
Column made of plywood
The 5 layers of 1,8mm thick plywood
Upright image of the wooden column
The template I used for marking and cutting out the column.
Z axis, identical to the y axis
Z axis is attached
The same brackets as on the XY table
New Z axis motor mount, now the whole axis will be identical to the Y axis (left to right) This will be beneficial for the captive nut
