XY table
A project log for CNC machine V3: Mill
The third version of my CNC machine I’m making, all the pervious ones had serious issues with stability.
loufourmountainsloufourmountains 12/27/2020 at 11:070 Comments
XY table top view
Side view
Stoppers for the linear rails and not all screws are used yet because I will have to undo them anyways in a bit
Bottom view
Base rails to the base plank
Added trough bolts for more squareness and stiffness
Drilled and tapped
Table is mounted much more secure, I added a larger diameter for the fasteners connecting to the linear bearings, so my imperfections can pass trough without any issues of alignment
Of course i still have to tighten the nut, but I do that when I am sure that I like it this way
