Varia
A project log for CNC machine V3: Mill
The third version of my CNC machine I’m making, all the pervious ones had serious issues with stability.
loufourmountainsloufourmountains 12/27/2020 at 11:140 Comments
Base plate of 1.8 mm thick plywood, here is where I will be mounting everything on
This is a test
Column attachment to the baseplate
Drilled and countersunk underside
Overkill? I think not! Normally I am a big (big!!) fan of Torx drive screws, and I have a lot of Torx head screws in storage, about 1700, but I didn’t buy thick and long ones. I had to use 5x80 mm Philips head screws instead…
