Fix top enclosure
A project log for SpeakerIR
Enjoying TV with a smart Hi-Fi or speaker? Use your TV IR remote to control volume, instead of having the other one always around.
enrico-gueliEnrico Gueli 01/02/2021 at 15:290 Comments
I updated the top enclosure design.
The hole for the USB port was a bit too much to the left, and it's now centered.
The side walls were a bit too thin (0.90mm). I initially made them that thin to use some snap-fit. But it wasn't necessary in the end: the print tolerances make enough extra width in both top and bottom enclosure to make the necessary friction. With 1.80mm walls the case is now stronger, and it's much easier to remove the supports without breaking it.
