IKEA Bekant Desk Automater
Who has time to wait for minutes per day to push a button? Let's automate the motion of an electric IKEA desk with an Arduino Nano!
I have an electric IKEA Bekant sit/stand desk. It's designed so that you need to hold down the up and down buttons for the desk to move. The desk takes about twelve seconds to move from a comfortable sitting position to a standing position, and vice versa, for me. I certainly don't have time to wait for minutes... MINUTES I TELL YOU... per day to push a button. I made a simple automater using an Arduino Nano, some N-channel mosfets, several momentary switches, and the original desk control PCB cannibalized from a spare control panel.
While I could have used an actual schematic, I'm hoping the included Fritzing diagram will help ease the circuit layout process for anyone re-creating this project.
--- Parts I used ---
As an Amazon Associate I earn from qualifying purchases through links in my descriptions and comments. This helps me finance future videos at no additional cost to you. If you choose to support me in this way, thank you.
***All screws, washers, nuts, and standoffs are M2***
***All wire is 22awg solid-core***
1x IKEA BEKANT desk
1x Arduino Nano clones
1x Power jacks
2x MOSFETs
4x Buttons
4x Button caps
Protoboards
1x Female headers
Screws
4x Standoffs
Wire
6x 220 Ohm resistors
Holddown.stl
Original PCB holddown
Standard Tesselated Geometry - 1.45 kB - 01/01/2021 at 20:45
Download
Cover.stl
Enclosure cover
Standard Tesselated Geometry - 129.77 kB - 01/01/2021 at 20:45
Download
Body.stl
Enclosure main body
Standard Tesselated Geometry - 435.73 kB - 01/01/2021 at 20:45
Download
desk_automater.ino
Source code
ino - 1.95 kB - 01/01/2021 at 20:45
Download
  • 1
    Print the enclosure.
    Print the enclosure parts (see Files section), cleaning up the holes on the bottom surface of the body so that a washer and screw head sit below flush from the surface (the flat side will be placed flat against the underside of the desk).
  • 2
    Remove and open the control panel.
    Unscrew the control panel from your desk.
    Open up the control panel case using a dremel, pliers, cutters, and/or a screwdriver as needed and remove the flexible button PCB. BE CAREFUL NOT TO DAMAGE THE PCB! It is only slightly below the control panel case you'll be cutting. IKEA sent me a spare, but shipping takes a while.
  • 3
    Solder the boards.
    Solder the two boards shown below (What I call the "main PCB" in the video is on top, and the "button PCB" is on the bottom; I realize they aren't technically PCBs, I just want to remain consistent with the video's phrasing). Be sure to add headers underneath the pins of the Nano; don't solder the Nano directly to the board (it makes replacement easier later, if necessary).
    The main PCB has 24 columns, 18 rows. The button PCB has 28 columns, 6 rows. All resistors are 220 Ohm. You will have to drill out one of the holes to fit the negative lead of the power jack. After drilling, bend it over and solder it to a nearby hole for structural support.
View all 17 instructions
