making the gusset
A project log for practice backpack
in dressmaking this is called making a muslin
kristina-panoskristina panos 01/10/2021 at 19:540 Comments
Last night I made the gusset, which includes the bottom and part of the sides. The top and the rest of the sides are called the zipper panel.
First I sewed the two exterior gusset pieces together.
Then I pressed the seam and topstitched it on either side.
Then I cut out the side pockets from the interior fabric and interfaced them. I found a perfectly-sized scrap of interfacing in my stash!
Next I folded the raw edges of the short sides under and topstitched along the top of the pocket.
Then I sewed the pockets on to the gusset.
Next I made the weird little loops that serve no purpose but add visual interest.
Finally, I sewed the two interior gusset pieces together, topstitch on either side of the seam, and sewed the completed lining gusset piece to the completed exterior gusset piece.
