A Simple Method to Measure Coffee Colloids
A novel and inexpensive technique for measuring colloids.
bobbob
This project started with the intention of quantifying the differences between coffees brewed by various methods. The result is a novel technique for measuring colloids. A theoretical explanation of why and how it works and practical details about the use of the Raspberry Pi High Quality camera for data gathering. will be forthcoming.
Index
This page is the introduction.
Statistical Analysis
The Effect of Particle Size
Laser Calibration 1
Laser Calibration 2
What's a colloid?
Colloids are particles which are larger than molecules but are small enough that they stay dispersed in the coffee. They scatter light. When you shine a laser through a colloid dispersion, you can see the light beam. link
Do colloids matter for coffee?
Colloids and acids are two things that change depending on the brewing method. link
One major purpose of Traditional Cupping is to greatly enhance Brew Colloid formation, so that the broader spectrum of a coffees flavour can be perceived.
How does this project work?
We shine a laser through diluted coffee and take a picture of the resulting light beam. By analyzing the picture, we can tell how much light reaches the camera from each point along the light beam.
Results
unpack.py
This takes a Raspberry Pi High Quality Camera RAW file and extracts the red pixel data along the laser beam.
x-python - 1.09 kB - 01/07/2021 at 14:03
Download
getMaxVals.py
This takes the data file generated by procLaser.py and extracts the red values along the laser beam. The result is maxVals.txt which can be plotted.
x-python - 653.00 bytes - 01/07/2021 at 13:15
Download
procLaser.py
This extracts data from a jpg file and puts it in a file named data.txt The image must be 2272x1704 pixels. If the image isn't the right size, which is likely the case, run the convert command as outlined in Step 1 of the instructions.
x-python - 598.00 bytes - 01/07/2021 at 13:10
Download
This is a way to keep the laser pointing down the middle of the graduated cylinder and to have a consistent camera position. The clothes pin holds the push button depressed.
Portable Network Graphics (PNG) - 376.38 kB - 01/06/2021 at 20:57
Preview
  • 1 × A toy cat laser https://www.kongcompany.com/cat/essentials/laser/laser-pointer
  • 1 × A graduated cylinder When you're analyzing the data, the dimensions of the cylinder matter a lot.
  • 1 × A camera
  • 1
    For most cameras
    Nota Bene
    Digital cameras do a lot of processing. Try to run your camera in as manual a mode as possible. I set the Canon A520 to aperture priority and set the aperture to f-8.
    The heart of this project is the ability to extract data from an image file.
    For most cameras use the following procedure.  For RAW images from the Raspberry Pi High Quality Camera, follow the instructions are in the next section (ie. Step 2).
    To extract data from a jpg file, I have written procLaser.py
    NB: the image files were created by a Canon A520.  They are 2272 x 1704 pixels. Your camera is probably different.
    If necessary, install imagemagick.
    On the command line do:
    You will have to change the image name.  ie. img_00001.jpg becomes whatever your camera created.
    Unless your image is upside down, you don't need: -rotate 180
    procLaser.py relies on the Python PIL module.  In Ubuntu, that module can be found in Synaptic..
    On the command line you can do:
    sudo apt install python-pil
    Anyway, you have to install python-pil before you can use procLaser.py.
    procLaser.py requires that you name your image file laserCylinder.jpg.
    It produces an output file called data.txt.
    python getMaxVals.py
    You will get a file called maxVals.txt which you can plot using gnuplot.
    In gnuplot do:
    plot "maxVals.txt" using 1:2 with lines
    If you want to save the resulting graph, you can do:
    set term png
    set output "someFileName.png"
    replot
  • 2
    For the Raspberry Pi High Quality camera in RAW mode
    These are the instructions for the Raspberry Pi High Quality camera in RAW mode
    The command line instruction to take a picture is:
    That sets ISO at the minimum value.
    The exposure time is 1,000,000 us = 1 second.
    The -r specifies a jpg file with RAW data.
    The aperture on the wide angle lens was wide open.
    To process the data I have written unpack.py.
    It's necessary to edit to change the file name for each image.
    My program is based on this excellent article.
    Note that, for the purposes of this project, I only care about the red pixels so that's all unpack.py deals with.
    unpack.py produces a data file named maxVals.txt.
    To graph the data in gnuplot do:
    If you want to save the graph, do:
    set term png
    replot
View all instructions
