This platform was created to allow modular development and experimentation of robotics in python / C++ using the Raspberry Pi and Arduino.
It is currently configured as a bipedal companion robot.
Features
Personality: Variables that are affected by external stimuli affect behaviour.
Facial detection and tracking: using the Raspberry Pi camera. Training algorithm allows the robot to learn new faces.
Servo control: control of up to 9 servos via an arduino serial connection.
Battery monitor: both external and software integrated via the arduino serial connection.
Auto shutdown: GPIO 26 is wired to allow shutdown when brought to ground via a switch.
Buzzer: A buzzer is connected to GPIO 27 to allow for tones to be played.
Braillespeak: The buzzer uses tones to communicate words using a sequence of tones.
Motion Sensor: an RCWL-0516 microwave radar sensor is equipped on GPIO 13.
Stereo MEMS Mics: GPIO 18, 19 and 20 allow stereo MEMS microphones as audio input.
Speech Recognition: enabled whenever a face is visible.
Power saving relay: connected to disable power to servos when not in use.
Neopixel: WS1820B support is included via the Pi GPIO pin 12. Unfortunately to support this you must disable audio on the Pi.
ah that's a cute one!
