The Water Watcher
Monitoring the pilot light on my water heater.
This project consists of two parts (or three parts if you count the MQTT server through which they communicate, or four parts if you count the wifi router, or, hey, just stop counting). One part is a sensor that monitors the status of the pilot light and main burner in my water heater. The other part is small LED matrix that graphically displays that status. The monitor broadcasts the status over MQTT every 30 seconds, and the display is updated based on the status messages. This is all done locally on my wifi network. No cloud services are involved.
My home's water is heated by storage tank water heater fueled by natural gas. Even though the water heater is fairly new, it uses a pilot light to light the main burner when it needs to heat the water. The advantage of that is that the operation is completely free of electricity. It's all driven by water pressure and some miraculous combination of thermal and mechanical stuff.
One of the disadvantages of using a pilot light is that it is always burning a little fuel, 24/7/365. It's amazing to me that systems like that are so widespread, but there we are. (My gas range, oven, and furnace do not have pilot lights. They use some kind of electrically-powered lighter to ignite the main burners when needed.)
At my house, there is another weird disadvantage: a few times a year, the pilot light goes out. I discussed that with a "water heater guy", and he immediately told me that he noticed on his way up my driveway that the exhaust outlet was not tall enough above the roof. According to him, the wind can hug the roof and sometimes blow back down the exhaust stack and blow out the pilot light. Is he right? I don't know, but I do know that something puts out the pilot light.
The pilot light only goes out 3-4 times a year. When it does happen, which is almost always noticed first thing in the morning, after I've waited in a stupor for an incredibly long time for the shower water to get hot, I trudge from the upstairs bathroom down into the basement. Then I do a kind of acrobatic headstand while using all three of my hands to go through the pilot light re-lighting procedure.
Sure, sure, I should talk to some more water heater pros and get this thing resolved for good. Someday. In the meantime, I've cooked up this remote monitoring system so I can at least know at a glance that the pilot light is out and the water is cold. My family's admiration for my level of technical geniosity more than makes up for the occasional tepid shower.
Even though this project is essentially complete, I'm going to give most of the details in the Project Log section since that's the best way to describe the several discrete pieces of information. So, start at the bottom and read upwards.
To make things immediately exciting, here is a short video of the Water Watcher in action:
The things you see in the video are the same things you see in the still images in this project's gallery, though the video gives a better look at the intentional flickering effect. The main picture in the gallery is the Water Watcher on duty in the master bathroom.
waterbug.yaml
This is the esphome config for the device that reports on the water heater flame status.
application/x-yaml - 5.30 kB - 01/11/2021 at 01:22
Download
waterwatcher55.yaml
This is the esphome config file for the monitor/display device.
application/x-yaml - 13.38 kB - 01/11/2021 at 01:22
Download
waterbug-OLD.yaml
Previous version, before ESPHome supported TSL2591. You probably don't need this.
x-yaml - 5.62 kB - 08/19/2021 at 02:24
Download
  • 1 × Any ESP8266 board
  • 1 × M5 Atom Matrix A small ESP32 gadget with an integral 5x5 RGB matrix
  • 1 × BME280 environment sensor on an I2C breakout board temperature, humidity, pressure
  • 1 × TSL2591 light sensor on an I2C breakout board
  • 2 × USB power supply
View all 9 components
  • The end of an era
    WJCarpenter09/10/2023 at 01:03 0 comments
    The time has finally come.
    Some article I was reading reminded me that I should check the sacrificial anode rod in my water heater every once in a while. A conscientious person should check that about once a year and probably replace the rod every 2-4 years to extend the life of the tank. Well, I have never done that. While looking things over to see how hard it would be, I noticed the date on the sticker that was put on the tank when it was installed. It's now 12 years old. The conventional wisdom is that the life of a storage tank water heater is around 10 years. OK, forget changing the anode rod. I'm replacing this water heater with a tankless natural gas water heater, and that's just a few days away. The new water heater will have electronic ignition, so this whole project for monitoring the pilot light will be moot within a few days from now.
    I am doing a small project for remotely triggering the recirculation pump on the new water heater (similar to what I described in an earlier project log, The double duty button, but a lot of details are different). If you want to read about that project, I'm describing it here: Calling for hot water.
  • Too bright or not so bright
    WJCarpenter08/16/2023 at 02:20 0 comments
    Along the way to implementing the ad hoc how water recirculation, I reflashed the Atom Matrix multiple times. Most of those times, the device lost its mind and turned on all the LEDs at full brightness. Sometimes it would recover if I cycled the power, and sometimes it did not.
    I spent a lot of time fooling around with different past versions of ESPHome (which I run as a docker image, so trying older versions was pretty simple). I also did a little Internet-style research on the FastLED library, which is what is used to control the animations.
    Eventually, through trial and error, I hit upon the answer. I display a rainbow animation at boot-up, just as a signal that no flame status message has been received yet. I added a few seconds delay before displaying that initial animation. My hypothesis is that I was previously interfering with the initialization of the WS2812C controller for the LEDs. Why this suddenly matters now is probably just other subtle changes in how fast things happen during the ESPHome start-up sequence. In other words, it was always a problem, and my luck suddenly changed
  • The double duty button
    WJCarpenter08/16/2023 at 02:12 0 comments
    I have a hot water recirculating pump tied into my home plumbing. On a schedule, it pumps hot water from the water heater through the hot water piping. A temperature sensitive valve located at the distant end allows that pumped water to flow back down through the cold water piping. The idea is that there is hot water at the ready, and you don't have to waste water running it down the drain until it gets hot.
    The timer on the recirculating pump is the tried and true analog type. It's a round dial, representing a 24-hour day, that slowly spins. Around the edges are a series of pegs that control whether the pump is on or off during any particular short time segment. Since I run Home Assistant for many reasons, I decided to convert the timer on the recirculating pump to be controlled by Home Assistant automation. No, I didn't rewire the timer. Instead, I turned all of the little pegs to the "pump is on" position, for all times of day and night. Then I plugged the pump into a smart socket. (The smart socket is an Sonoff S31 reflashed with ESPHome, as described in this and subsequent project logs.)
    To control the smart socket, I created a Home Assistant schedule helper object. The schedule helper is a list of times when the schedule is "on"; otherwise, it is "off", and you can use the state of the schedule as a trigger in Home Assistant automations. I created an automation triggered by any state change in the schedule. The resulting action is a "choose", which turns the smart socket off if the state of the schedule is off and on if the state of the schedule is on. It works as desired. In YAML form, it looks like this:
    alias: Hot water recirculation SCHEDULED
    description: ""
    trigger:
      - platform: state
        entity_id:
          - schedule.hot_water_recirculation
    condition: []
    action:
      - type: turn_on
        device_id: e3bfbdb764cdef92f454e345ec3e1042
        entity_id: switch.s31_green_orange_relay
        domain: switch
      - choose:
          - conditions:
              - condition: state
                entity_id: schedule.hot_water_recirculation
                state: "on"
            sequence:
              - type: turn_on
                domain: switch
          - conditions:
              - condition: state
                state: "off"
            sequence:
              - type: turn_off
                domain: switch
    mode: queued
    max: 10
    If I want to change the schedule, I can do it in the Home Assistant GUI (or by manually editing a config file), and everything else automatically flows from that. (Heh, flows. Get it?)
    For my own highly regulated self, that scheduling is enough. But there are others in the household who want hot water at various times that are not really suitable for predictable scheduling. I wanted to provide a way for them to summon the hot water without a lot of fuss. I decided to use the button already present on the M5Stack Atom Matrix device, the device that is already in use to display the hot water heater flame status. On the Atom Matrix, the entire front face is a GPIO button. I've been using it for a simple way to cycle through the display modes of the device. I'm now overloading that button to also signal the desire for hot water recirculation.
    My first draft of the implementation was to create a Home Assistant input button helper. It's simple enough for an ESPHome device to call a service in Home Assistant, so it's pretty easy to have the physical button press on the Atom Matrix cause a logical press of the Home Assistant input button helper, and that in turn can be used to trigger an automation. I abandoned that scheme for a light-weight reason. The implementation of this project uses MQTT to communicate among the devices. The devices still show up in Home Assistant via the MQTT integration. To call the service to logically press the input button helper, I'd have to use the Home Assistant API integration. That all works fine, and the API and MQTT components in ESPHome co-exist just...
  • Long, long time ago
    WJCarpenter08/06/2023 at 20:05 0 comments
    I've been thinking lately how i have not had a genuine pilot light outage for quite a while. In fact, for a long time. I think it's because I had solar panels installed on the roof a couple years ago, and some of the panels are in the same area as the exhaust stack for the water heater. I'm thinking that maybe that changed the airflow around that part of the roof so that the whatever-it-was-that-blew-out-the-pilot can no longer do that.
  • coming back to my sensors
    WJCarpenter11/18/2022 at 01:08 0 comments
    It turns out I was completely wrong about what was going on with my faulty sensor readings. It took me weeks to figure it out, partly due to my own carelessness. Here are some thing I tried that did not work:
    • Piece by piece, I replaced every physical part of the system. That includes even things like the little breadboard that holds the ESP32 and the jumper wires that connect everything together.
    • I changed the update intervals for the two sensors. My hypothesis was that there might be a weird timing error where device access on the I2C bus was overlapped. I had been using 30 seconds for the TSL2591 and 60 seconds for the BME280. I changed both of them to nearby prime numbers so that they would very rarely want to be read at the same point in time.
    • I moved the BME280 to a separate pair of I2C pins. The ESP32 supports two separate I2C busses, and most of the GPIOs can be configured to be SDA/SCL.
    • I changed my scripting around so that the ESPHome "interval" was used to ask the sensors for updates sequentially with short pauses in between. My hypothesis was that I could force access to the I2C bus to be a single device at a time.
    • I switched the TSL2591 from powersave mode to always on. In powersave mode, the device shuts down between readings and needs to go through an ADC integration cycle of about 600 ms before values can be read.
    • I changed the I2C bus frequency to a couple of different values.
    • With the idea that heat on the TSL2591 might be affecting the whole system, I used some screws and nuts to make stand-offs to hold the TSL2591 board a half inch or so away from the glass. Hee's a picture:
    • I removed the TSL2591 completely away from the water heater glass and just had it watching a little lamp.
    • I modified the scripting so that if a value was not actually read from either sensor, I would reset the I2C bus and the sensors. You can do that in a lambda call. Weirdly, that sometimes worked and sometimes rebooted the ESP32.
    • I added a text sensor to make it easier for me to monitor what was going on without tailing the ESPHome log all the time. The same script that sends the messages over MQTT updates that text sensor with the same value. This is a standalone system, but since I also run Home Assistant, it's easy to monitor all the sensors, view a logbook of changes, view history, etc. I used the special text value "RESET_I2C" (just for the text sensor) so it was easy for me to see when that activity kicked in.
    • I modified the script to notice whether things got better after resetting I2C. If not, and it carried on for more than a few minutes, I used another special text value "REBOOT_ME" for the text sensor. Early on, I got tired of tromping up and down the basement stairs just to cycle the power, so I plugged things into a WiFi-controlled smart socket that I could toggle from Home Assistant. I also set up a Home Assistant automation that would watch for the "REBOOT_ME" text and then cycle the power. I felt pretty smart about that, but I never actually saw it happen.
    # This is an explicit text sensor that gets the same value as the
    # message we send to waterwatcher. No explicit update interval because
    # a value gets published when we do the rest of the flame status
    # processing.
    text_sensor:
      - platform: template
        name: "${node_name} flame status text"
        icon: mdi:fire
        update_interval: never
    • I set up another device that was an identical twin. It has the same model of ESP32 board, the same model of TSL2591, and the same ESPHome configuration (other than the node name). I had it laying around on my desk, and it worked perfectly. That was odd since the parts were those that I replaced early on in the troubleshooting.
    • I moved the twin down to the basement, and it started being flaky. Could it be something like a few degrees colder temperature, trace amounts of natural gas fumes, lack of cosmic rays, ...?
    OK, if you've read this far, you may have already guessed. The problem was the USB power supply that...
  • Stuff and non-sensor
    WJCarpenter10/15/2022 at 22:54 0 comments
    [Edit: Forget all this. See next project log article.]
    In July 2021, the TSL2591 ambient light sensor I was using went bad. I replaced it, and things went back to normal. In the last couple of weeks, that replacement sensor went bad. It's probably due to the somewhat warm conditions the sensor lives in. I have replaced it again with another Adafruit breakout board, and now things are back to normal. I guess replacing the sensor every 14-15 months is not too bad, all things considered.
    Before the sensor went completely bad (giving a reading of 0xFFFF on one of its sensors), it sputtered for a while. By that, I mean that I could reboot the device, either with a software reboot of the ESP32 or with a power cycle of the entire setup, and the sensor would sometimes come back to operating normally. It also had a failure mode where both sensors reported 0 readings. Partly as an educational exercise for myself, and partly to while away the time waiting for the replacement part to arrive, I explored detecting the problem and automatically rebooting the ESP32. That's not too hard in ESPHome, but it's also not immediately obvious unless you go digging into the C++ platform APIs. I don't think there's any "on error, do this" in ESPHome.
    I set up a recurring check with the ESPHome "interval" component. It runs an ESPHome script once a minute:
    interval:
      - interval: 60s
        then:
          - script.execute: periodic_reboot
     The script itself is imperfect but might still serve as a useful example.
      - id: periodic_reboot
        then:
          - if:
              condition:
                # We delay 10 minutes before rebooting. Otherwise, if the sensor is broken, we'll
                # instantly reboot after a reboot, and it will be very difficult to do a
                # firmware update or anything else.
                lambda: 'id(device_uptime).update(); return id(i_tsl2591).is_failed()  &&  id(device_uptime).state > 600;'
              then:
                - logger.log: {level: ERROR, format: "TSL2591 sensor is FAILED."}
                - switch.toggle: i_restart
    The script checks for an error condition on the TSL2591 component. If so, it does the software equivalent of pressing the reset button on the ESP32 board. The first time I ran this, I didn't account for the fact that the first time the check happened was immediately at boot time, so an error in initializing the TSL2591 led to a boot loop. It's a bit tricky to be able to update the firmware in the ESP32 when it's in that condition. If I had already had the replacement TSL2591 on hand, I could have plugged it in and eased my pain. Instead, I just kept iterating attempted updates until I got lucky. The update include the check for being up at least 10 minutes before forcing the reboot.
    The script you see above is not good enough because sometimes the sensor would seem to initialize OK and also not raise an error during a read cycle. Instead, it just gave back readings of 0. I also had a version of the script that checked for a value of 0 in the global variable CURRENT_FULL_SPECTRUM. That had the problem of causing reboots during the "dazzle" period that is a normal part of the flame cycle. I've thought a bit about various ways to make the check better, but in the meantime my replacement sensor arrived, and I've got better things to do, and yadda, yadda, yadda....
    An interesting thing happened after I installed the new TSL2591 sensor. The BME280 climate sensor on the same I2C bus went bad. That sensor is not housed in the same heated environment as the TSL2591, so having it go bad at about the same time seemed a bit suspicious. I've now replaced that sensor (I had a couple of spares on-hand). My hypothesis right now is that the dying TSL2591 sensor put some kind of signals on the I2C bus that caused the BME280 to lose its mind, but beyond that I don't know much about what might have happened.
  • Back and in color
    WJCarpenter09/28/2021 at 03:27 0 comments
    I finally got around to fixing the colors of the LED animations on the display device. For a long time, I thought that something had changed subtly in the color model used by ESPHome and that it would be a lot of bother for me to get back to the colors I wanted (and that show in the videos on this project). It turned out to be something simpler, though still an infrastructure change somewhere along the way.
    To give the totally awesome "world on fire" look to the display, I'm using the ESPHome fastled component. Specifically, I'm using the addressable flicker effect. It has a tunable parameter for how much the flickering can vary from the base color of the LED. I had been using 25%, which looked good in the original incarnation with an older ESPHome release. I cranked that "intensity" value way down and, after some experimentation, settled on 7% variation. It now looks pretty much like I wanted.
    I have updated waterwatcher55.yaml to reflect this change (and to correct one other unrelated typo.)
    This is probably the last log entry for this project. That is, unless I think of something else. :-)
  • ESPHome supports the TSL2591
    WJCarpenter08/19/2021 at 02:29 0 comments
    ESPHome release 2021.8.0, just released, includes my PR to directly support the TSL2591 sensor. My previous waterbug.yaml depended on loading support as a custom component, along with the Adafruit TSL2591 library. The ESPHome support uses the ESPHome I2C abstraction and does not use the Adafruit TSL2591 library at all. A nice side-effect of that is no longer needing to configure a fake "spi:" entry because of the Adafruit standard sensor library's dependency.
    Changes to waterbug.yaml to use the ESPHome support for TSL2591 are minimal and are mostly removing things. I updated the YAML files on this project to reflect the changes.
  • I see the light
    WJCarpenter08/06/2021 at 21:10 0 comments
    Well, that was silly. I didn't pay close attention to this before, but what I have been calling "lux" throughout is not lux at all. It's still a useful value (for this scenario), but it's just not lux.
    ESPHome supports the obsolete TSL2561 device but not the replacement TSL2591 device. Over the last few days, I undertook adding support for the TSL2591 device to ESPHome. (Here are the pull requests, if you are interested: https://github.com/esphome/esphome/pull/2131, https://github.com/esphome/esphome-docs/pull/1370). It was only while working through the details of that that I started paying more attention to what I was measuring.
    What I have been calling "lux" is actually just the raw value of a 16 bit ADC for one of the sensors on the device. To get actual lux values, you have to do a calculation based on the ADC readings of both sensors. The calculation involves the configured gain, the configured integration time, and some empirically-determined coefficients. It is fairly complicated and scenario-specific to tune the calculation, but there is a calculation implemented in the Adafruit TSL2591 library. (Actually, there are 3 different calculations there, but 2 of them are commented out.)
    In my ESPHome integration, I decided to make the raw ADC values available in addition to the calculation provided by the Adafruit library. That way, anyone who wanted to do their own calculation would have the inputs they needed (well, they also need a handful of physical characteristics that are out of scope for how much work I am willing to do for my own feeble efforts).
    What does this mean for this project? Not much, in practice. I'm going to continue using that raw ADC read-out ("full_spectrum" in the graphic below), even given my better understanding of what it is, because it suits the coarse-grained conditional logic needed here.
    I did not have an intuitive feel for real world lux values (like I do for furlongs, fortnights, and shillings and pence) until I looked at the Wikipedia article about lux. It has a nice table of a few examples. It tells me that what I see when the pilot light is on the order magnitude of some kind of moonlight on a clear night. Fair enough.
    Here are some sensor readings that show the ADC values (600ms integration time, 428x gain) as well as the lux calculation from the Adafruit library:
  • Sense and sensor ability
    WJCarpenter07/06/2021 at 01:18 0 comments
    A couple of weeks ago, readings from the light sensor went crazy. Starting at a certain point, the only two values ever reported were 0 and 64k. The latter (actually 0xFFFF) indicates saturation of the sensor. That was very bad for the use case, so I unplugged the upstairs display while I worked on it.
    This started happening remarkably soon after I applied an ESPhome update and reflashed the code on the ESP8266 hosting the light sensor.  Since the driver for the TSL2591 is a custom component in ESPhome's point of view, I thought maybe there was an incompatibility in the update. I spent a lot of time horsing around with trying to get  an older version of ESPhome and matching PlatformIO working. That's probably a pretty simple thing for someone more familiar with that ecosystem, but I was basically in dependency hell. I eventually gave up and just ordered a new sensor in the hope that it wasn't a software problem after all.
    Lo and behold, with the new sensor in place and firmware from the latest ESPhome, things were completely back to normal. So, I guess the sensor was bad after all. I haven't had a chance to play around with the CQRobot sensor to see if I could figure out what made it angry. I hope it's not the case that the heat coming through the viewing window eventually destroys the sensor. It would be a disappointment to have to replace it once or twice a year.
    For the replacement sensor, I switched to Adafruit's board for the TSL2591. Like the CQRobot part, it has a nice socket for an interface cable, though it's a different size (a bit smaller in all 3 dimensions). I got lucky on shipping, and it arrived from New York City to my Seattle-area home in just 3 days. W00t!
    The readings for the 3 interesting states of the gas flame are not the same with this board. That could be related to manufacture of the board, factory calibration of the sensor, or something as simple as my placement of the board onto the viewport window. (Since this board has connectors at both ends, it sits naturally on the glass at a different angle than the CQRobot board.) Even though they are not the same values, they were still just fine for the thresholds I had already put into the firmware.
    (I was a little worried because I tested the board by shining a flashlight onto it. The readings were the 64k saturation value, and I feared it was a software problem after all. But I guess that just shows the high quality of my flashlight. Once I installed it on the water heater viewport, I got suitable values with no further adjustments.)
View all 21 project logs
[deleted]
WJCarpenter wrote 03/14/2022 at 20:06 point
What kind of help are you looking for?
Adam Quantrill wrote 01/22/2021 at 16:08 point
Nice! I was thinking of doing the same for my boiler (furnace in the US) which is old, the thermocouple wears out once a year or so. However I was thinking to use an extra K-type thermocouple in/near the pilot flame instead of the light emissions, as the observation window gets very hot when the boiler is on full. Also it could be fooled by ambient light. Secondly, instead of a display, I'll have a broadcast alert on the home WiFi that can be picked up by any device and displayed.
For your graph observations, would the explanation lie in the combustion, if it's complete and a blue flame then not as bright as incomplete and a few yellow bits?
WJCarpenter wrote 01/23/2021 at 03:30 point
I think the burner area of my water heater is completely sealed from at the bottom, though it's obviously open at the top for exhaust. So, for my case, there isn't a simple way to get any kind of sensor inside.
I also worried about ambient light, but it seems to not be an issue. The entire area is normally covered by a cottony fiberglass insulation layer, and that in turn is covered by a loosely-fitting metal plate.
I probably never will properly figure out the flame wavelength stuff. But maybe someday the right piece of inexpensive test gear will show up so I can actually measure it. I read a couple of papers about the characteristics of natural gas flames, but they didn't even agree with each other. :-)
WJCarpenter wrote 01/24/2021 at 19:41 point
I had another look at my water heater and the manual for it. It's only sealed in the sense of a plate held on by some screws and sealed with a gasket. So, I think I actually could  have used your idea of a thermocouple near the pilot light. At this point, I'm reluctant to do that since I have a working system. I also have plenty of experience with "improving/fixing" things and actually ending up making them worse, so I don't want to mess with disassembling that part of my water heater's innards.
Adrian wrote 01/19/2021 at 16:34 point
I'm impressed by the amount of energy and detail you put into this :) But I can really feel why you're doing this and how it feels nice to "beat" a problem like this with technology.
WJCarpenter wrote 01/20/2021 at 02:06 point
Thanks. It's one of those cases where I know I should just get the root cause problem fixed, but once I started imagining what a notification system would be like, well, I wanted to build it.
