Power Supply
A project log for N64 Raspberry Pi Retro Emulation System
Giving an N64 a new lease of life with a Raspberry Pi Compute Module 3
jackal123ukjackal123uk 01/05/2021 at 23:450 Comments
Turning toward the power supply it's easy to see that stock unit is supplied with 12V and 3.3V which is not fully compatible with the requirements of the compute module - namely 5V, 3.3V and 1.8V.
Strictly speaking you can run the compute module with only 3.3V and 1.8V but 5V is needed for HDMI and USB.
Since I've successfully used a circuit based around a PAM2306 regulator in the past I'll plan on using this to supply everything from a 5V source.  As I don't like playing with mains voltages I might hide a standard (read safe) 5V charger inside the power brick.
