1Step 1
This directory contains the necessary components to build a custom PCB enclosure
Update ~/DIMENSIONS with correct equations for your PCB
Rebuild ~/Universal_case_assembly
export the three components as .STL
Import and slice the .STL components
Print and enjoy!
danielcanaday
