TESTED_FLIGHTcontrolbirdfishv2_flightFixed.txtFlight tested.. With one error fixed.plain - 9.94 kB - 01/10/2021 at 01:10 |
controlParaSoundingv4.inoLatest version.. With lessons learned implementedino - 9.57 kB - 01/10/2021 at 01:10 |
exactflat.jpgtaking 3d surface and making flat patternJPEG Image - 75.06 kB - 01/08/2021 at 00:07 |
quadwing.f3dDesign of my own wing. cut files below are via exact flat. From 3d surfaces.fusion - 7.62 MB - 01/08/2021 at 00:05 |
celldxfs.f3dA Wing design cutfiles with seam allowance Fusion360 archivefusion - 806.60 kB - 01/08/2021 at 00:00 |
ribwing.pngRibs for wing designPortable Network Graphics (PNG) - 202.30 kB - 01/08/2021 at 00:00 |
AutoCAD DXF - 17.73 kB - 01/08/2021 at 00:00 |
AutoCAD DXF - 5.31 kB - 01/08/2021 at 00:00 |
AutoCAD DXF - 17.88 kB - 01/08/2021 at 00:00 |
AutoCAD DXF - 6.25 kB - 01/08/2021 at 00:00 |
AutoCAD DXF - 17.02 kB - 01/08/2021 at 00:00 |
AutoCAD DXF - 9.75 kB - 01/08/2021 at 00:00 |
AutoCAD DXF - 21.92 kB - 01/08/2021 at 00:00 |
AutoCAD DXF - 15.64 kB - 01/08/2021 at 00:00 |
AutoCAD DXF - 11.15 kB - 01/08/2021 at 00:00 |
AutoCAD DXF - 18.04 kB - 01/08/2021 at 00:00 |
AutoCAD DXF - 11.63 kB - 01/08/2021 at 00:00 |
AutoCAD DXF - 21.64 kB - 01/08/2021 at 00:00 |
AutoCAD DXF - 16.65 kB - 01/08/2021 at 00:00 |
AutoCAD DXF - 16.17 kB - 01/08/2021 at 00:00 |
ribprofilecutout.dxfattachment patch supportAutoCAD DXF - 22.43 kB - 01/08/2021 at 00:00 |
AutoCAD DXF - 29.54 kB - 01/08/2021 at 00:00 |
servoarm_birdfish4_bigV2.stlBirdfish arm for the big servos.Standard Tesselated Geometry - 294.71 kB - 01/07/2021 at 22:11 |
servoarm_birdfish3.stlNormal Birdfish arm for payloads less than 1.5kg. and windspeeds under 20mph. otherwise there is not enough control authority.Standard Tesselated Geometry - 193.25 kB - 01/07/2021 at 22:11 |
bigservoredesign.stlThe original Box shape derived from the foam high altitude design, but with larger servo placement for high winds, or wing loading.Standard Tesselated Geometry - 5.65 MB - 01/07/2021 at 21:49 |
birdNewV6.stlLast box shape design derived from foam high altitude design. Room for switches, speed system. Some other things..Standard Tesselated Geometry - 3.38 MB - 01/07/2021 at 21:49 |
coreV2_power_serv.stlEDF design more reinforcement. Ended up using bottom reinforcement to add weight to properly load larger wings.Standard Tesselated Geometry - 1.09 MB - 01/07/2021 at 21:49 |
core_power_serv.stlFirst EDF design.Standard Tesselated Geometry - 909.26 kB - 01/07/2021 at 21:49 |
