22-01-2021
Finally had some time to put all the parts on the map. Now comes the big work, programming and testing. First the memory mapper in the CPLD then the ATmega and then the Z80
08-05-2021
Build uploaded 2 files for the CPLD one is just a memory mapper and the second is the configuration for if you want to build a MSX computer with 512K Ram. its all tested and working fine. Now working on the software for the ATMega
