Simulator Install
A project log for MK-52 Resurrect
A Programmable Calculator from the USSR!
ptravptrav 02/21/2021 at 06:020 Comments
The simulator is fully operational, apart of the file Load and Save. The Alpha is available here:
https://github.com/myak555/MK-52_Resurrect/tree/main/Install
To install on Windows 7 or above:
To install on Windows XP:
To install on Linux under Wine:
sudo cp ~/.local/share/applications/wine/MK-52.desktop /usr/share/applications
Installation wizard steps:
At this point, Windows will dim the screen and ask to confirm the install.
