ML-derived kinematics
A project log for Love Elemental
A fuzzy, glowing, touch-responsive serpent using ROS + SOTA machine learning to make lifelike behavior.
david-greenbergDavid Greenberg 01/13/2021 at 22:180 Comments
(This is as-of December 25, 2020)
Due to the interesting structure of a universal spine joint with 2 actuated abdominal muscles, doing the trig for the inverse kinematics isn't as simple as it would be for legged robots. As a result, I ran a simulation that tried all the different servo positions. I measured the servo positions & spine angles and trained an lightgbm model to create a kinematics controller.
This video shows a the simulated robot doing a simple serpentine gait. While there's still a lot to do, I'm excited that some of the low-level components of the project are starting to seem real.
