Body Hardware Completed, Software & Head Next
A project log for Love Elemental
A fuzzy, glowing, touch-responsive serpent using ROS + SOTA machine learning to make lifelike behavior.
david-greenbergDavid Greenberg 12/15/2021 at 17:451 Comment
After nearly a year in R&D, the Love Elemental's body's hardware is pretty much done.
She's got 7 working segments with custom electronics and controls: each segment has a 120MHz Cortex M4 microcontroller that handles the LED visualization, motion planning, battery charging, and CAN-FD communication. The 'head' (which is a stopgap for the real thing) has a Lattepanda Alpha, which is a crazy-fast nearly 4GHz x86 board that's the size of a raspberry pi.
With the LEDs mounted on the ribs, the fur effect is definitely looking awesome!
The actuators are Lynxmotion LSS-HT, but I'm running into issues with overtorque or shutdown situations. Hopefully it isn't long before Ellie is swimming across the floor.
Dejan Ristic wrote 12/23/2021 at 15:10 point
What a beast!
Looks as if one of those prehistoric mega-centipedes mated with a vacuum cleaner or something :D
Hope you'll post a video of it in action when you get done with the software. Very cool!
