Grr, the brackets
A project log for DI Monitor
Monitor a color changing DI cartrige on an RO system, to determine when it needs to be replaced.
tim-rightnourTim Rightnour 02/01/2021 at 14:320 Comments
So I tried reprinting the brackets in white, with the IC's closer to the cartridge, and I'm still just getting the same values on both sensors.. sigh..  Not sure what is going on here..  I need to play with it more, maybe I have to put the sensor like directly on the thing to be measured?  Argh.
