Module control software for Arduino.
A project log for HP printer cartridge control module
HP 63/302/123/803 cartridge control module with 3D printable mount.
Pavel SemenovPavel Semenov 04/23/2021 at 10:360 Comments
Here is it, the software part of the project for Arduino board is ready and can be downloaded from github.
---------- more ----------
I've implement simple Arduino application to control cartridge ink jetting through module. It was not so hard as I expected, since all cumbersome bit logic is implemented and well documented by Sprite_tm in his repository of simple printcart.
This code has not been tested with real hardware yet, but output pins diagram looks promising.
